Question about Kitchen Ranges
Amana Model ARGS7650
Watugot,
I see that you were able to answer someone else's question regarding this model of Amana slide-in. My friend has a similar problem. The digital keypad control for the oven portion has gone blank, and will not work. I believe it is probably just a bad keypad. However, I cannot figure out how to access it. There are two small cover plates which access the area under the burner control knobs, but I cannot reach the connector to the display/keypad or figure out how to remove it. Here is the info: Model ARGS7650 WW, P1130759NWW. My email adx is kingjc4me@comcast.net
watugot
  • 290 Answers
SOURCE: my Amana ARGS7650
Turn the power off to the range.
If you have the duel fuel model, remove the burner knobs and remove the screw behind each knob.
Open the oven door and reove the four screws that hold the bottom of the control panel to the range.
The panel should pull out and down at the bottom.
You will probably find the ears that hold the board have broken. Some of these models only used two screws to hold the board to the panel, which left two ears that you can put the screws in to fasten it back in place. If all four ears are broken, I have used flat washers under the screws to fasten it back if there is enough of the ear left for the washer to catch.
Posted on Oct 16, 2007
  • 415 Answers
SOURCE: Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Posted on Sep 13, 2008
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
SOURCE: Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Posted on Apr 06, 2009
what ge gas oven was purchased for replacement part
Posted on Aug 01, 2009
My Amana ARGS7650
Oct 16, 2007 | Amana ARGS7650 Electric Kitchen Range
Replace circuit board in amana 26" TTW unit ?
You are asking for a generic answer regarding a non-generic subassembly...in effect asking for an amana maytag service person to provide a free answer. In such a situation as that it is always advisable to include a photo with your question...so people will be able to see the problem. Use the add and image command just below the text input box.
Oct 28, 2014 | Amana Heating & Cooling
Burner igniters not working
Plug it in. lol.
Can you confirm you have power to the unit?
Check breaker.
May 15, 2010 | Amana ARGS7650 Electric Kitchen Range
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Dec 25, 2007 | Kitchen Ranges
Amana range will heatup then turn it's self off
F3 F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Oven temp. sensor needs to be replaced. You should be able to look at diagrams with the model # for part location @ http://www3.sears.com/ or http://www.appliancepartspros.com/. The sensor looks like a rod about 4-6 inches long and mounted to the back wall inside the oven. Some can be pulled out from insided the oven by taking out the two screws. If no screws then you will have to pull the oven out and remove from the back.
Nov 07, 2007 | Amana ARGS7650 Electric Kitchen Range
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
