Question about Holmes Products Cool Mist HM3500 Humidifier
1Touch HM1295 humidifier part # 7911000006583
Part 7911000006583, is priced at $3.00 plus shipping and handling. It is the screw-on cap for the water container.
I need this part. How do I order it and pay for it.
Pierre du Vair, tel 418-656-0203, duvair@videotron.ca
  • 10,515 Answers
Hey,
http://www.bionaire.ca/holmeshm1295.html
Click he above link and pay using Credit or Debit Card. ( Master, Visa or American Express )..
Believe me, this is the best site to purchase humidifier parts :)
Thanks.
Posted on Dec 16, 2008
  • taran_2005
    taran_2005 Dec 16, 2008
    U CAN ALSO CALL THEM :)
    In CANADA and the USA Call us 905-469-1536
  • 13,433 Answers
  • 19,396 Answers
This should be the part description:
AMRE Supply - Canada's Parts Pros [ 7911000006583
  • Ginko
    Ginko Dec 16, 2008
    Yes , the part SKU: 7911000006583 is the humidifier cap, that is the cap covering the humidifier water tank:
    BIONAIRE HUMIDIFIER CA..
    Call the seller at 1-800-387-3131 to get more details, or to order the part.
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
Need two tank caps with gaskets
Fixya does not sell replacement tank caps.
Sep 03, 2017 | Bionaire W6 Whole House Humidifier / Air...
I can't seem to get the water to flow freely from the tank to the humidifier. When I plop on the tank, a few bubbles enter and some water goes into the humdifier, but after that initial flow, no more...
I read you rite,t the humidifier won't supply enough water to wet the roller . If so then follow the fresh water line down to the shut off valve. Most likely a saddle valve. with screws holding the valve tight to the side of the water pipe. I have had many of these plug up with junk in the water over time. best suggestion is to screw in the valve all way till it stops hard ,like suddenly. If it very stiff to turn the valve get a wrench and loosen the collar nut just a bit so the valve screw handle will screw in and out easier. Remember clockwise is in or OFF, and Counter clockwise is open or out. Run this valve closed and open a few times, then check the humidifier float for proper water level. Good Luck, Bill
Jan 07, 2018 | Germ Guardian H2000 14 Gallon Humidifier
Where can I buy replacement water-tank caps for a Bionaire W12? Also, what's the difference between Bionaire W12 and W12-UC?
i just ordered a replacement cap for the w-12 it has a funnel on the end the one i have don't but the man said it will do the same thing. the funnel is for pouring the water in. the website is appliancefactoryparts.com it cost around 28.00 thats including the shipping and handling of 7.99
Nov 15, 2010 | Bionaire W12-UC Humidifier
Humidifier Water antibaterial additive
Hello. Humidifier water tanks must be regularly disinfected to remove the presence of bacteria and reduce the risk of mold spores. Carefully remove the screw-on cap, fill with cool water and add a tablespoon of household bleach to the water. Replace the cap and set aside for 20 minutes. Once done, empty the water tank, rinse thoroughly with clear cool water, and wipe the outside with a soft damp cloth and you are good to go. Do this once per week. Regards, Joe
PS please rate my answer. thank you.
Jan 06, 2010 | Crane Panda 1 Gallon Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
He220a honeywell humidifier water actuator valve broke
The screw does turn and will open the valve, take the hex nut off and turn the screw to see if water leaks between the valve portion and the hexnut housing. They used that same valve on many models, including the newer models. Make sure you are getting water to the valve.
Nov 26, 2008 | Honeywell HE220A1019 Whole House...
Lost the valve cap for the water tank
You can buy a replace tank cap online from Crane. As of the time of this writing, this link will take you there: http://shop.crane-usa.com/products/productdetail/part_number=EE-0865-1cap/1779.0.1.1
The cap is about $5, plus $5 shipping in the US.
Sep 26, 2008 | Crane Penguin 1 Gallon Humidifier
Holmes Products Cool Mist HM3500 Humidifier Logo
134 people viewed this question
Top Holmes Products Humidifiers Experts
ray gallant
Matthew Wyatt
Level 1 Expert
Tom Chichester
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
