I can't seeem to search the internet. When I try to search it closed the program. It says something data executive management. I read a bit about it basically it shuts the program when it detects something malicious..new computer.
  • George Bill
    George Bill May 11, 2010
    First we would need to know how you connect to the net, modem, cable, dsl, etc, then you have to make a connection either using the wizard or a browser. If you just pluged a new machine in, without configuring it for the type of connection you have, nothing will happen. You deed to be specific, like this, I have a ---, computer, using ---Operating system, and a --- modem, how do I set it up. without the info, we can't help
  • 679 Answers
Shut off windows defender, andd tell me if that did it. I disable mine it just causes problems, if it worked I will show you a site to get exellent virus and other programs, that I have been a member of for 10 or more yrs.
Posted on Dec 18, 2008
  • 611 Answers
Http://www.sowsoft.com/search.htm
you go this site and download the tols after then installed it then restart your computer thewn you get it
Posted on Dec 16, 2008
  • 57 Answers
Actually he is wrong the problem is a Virus or Spyware or similar bugs that you must;ve gotten through the Internet. I strongly recommend scanning your pc and getting them removed.
When I had this before my only solution was to wipe my pc and start over as the DEP or Data Execution Protection stopped most of my programs.
Annoying I know but this is why I say Microsoft should not have put the DEP in vista or made it able to be Disabled.
Pcviewer only searches for hdd when first installed
You need to run the program as the administrator.
This will allow the program to scan for connected dvr.
May 23, 2012 | Signet Home Security
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
I have problem opening the photos from a friend in picassa
Hello
This problem can be resolved by opening the "Control panel" and selecting "All Profiles" under the "Color Management" file. Add the "sRGBIEC61966-2.1" profile to the "ICC Profiles."
Make sure that the digital photo file that you're trying to access isn't open or in use by another program on your computer. Oftentimes, two programs can't access the data contained within a file at the same time. If your photo is already open in another program, for example, you wouldn't be able to open it in your digital photo viewer/file manager.
Make sure that the file format of the digital file you're trying to open will actually work with the file manager you're trying to use. Not all programs are going to be able to open every file type. There are dozens of different photo files types in existence. Look at the photo file's extension and then look in the instruction manual that came with your file manager to determine if that program can read that particular type of file.
Reinstall your digital photo viewer file manager utility. If you purchased your program in a store, insert the CD-ROM you used to originally install it into your computer and select "Repair" when its setup program automatically opens. If you installed your digital photo viewer file manager utility from a computer file you obtained on the Internet, execute the original installation file and select "Repair" to reinstall your program on your computer.
Make sure you have the latest version of your digital photo viewer file manager. Programs are often updated by their original manufacturers to fix errors and issues that users have been known to have. Open your program and click on the "Help" tab. Look for an option that reads something like "Update" or "Check for Updates" and select it to connect to the Internet and make sure that you have the latest version of the program installed on your machine.
Nov 05, 2010 | Computers & Internet
Data execution
DEP (data execution prevention) attempts to separate "data" (such as the text of a webpage) from "instructions" ("move the string 'abc' to locations '12345/12346/12347'"), to prevent computer-hackers from introducing "data" (downloaded from a maliciously-constructed web-page) into an area marked as "instructions". The "threat" here is that the "data" will actually be "instructions" of the hacker's choosing, thus giving the hacker a chance to run instructions to completely "take-over" control of your computer.
Click "Start"
Click "All Programs"
Click "Accessories"
Click "System Tools"
Click "Internet Explorer (no add-ons)"
Do some web-surfing.
Close Internet Explorer.
If it closes "normally", then one of the "add-ons" that usually is loaded when Internet Explorer starts is causing the DEP exception.
Start Internet Explorer.
Click Tools
Click Manage Add-ons.
Choose one "suspicious" add-on, and "disable" it.
Close I.E.
If it closes normally, then that add-on should _stay_ as "disabled".
Nov 19, 2009 | Microsoft Computers & Internet
Internet Explorere keeps closing down
Data Execution Prevention (DEP) is a security feature that helps prevent damage from viruses and other security threats by monitoring your programs to make sure they use system memory safely.
Here is a link to an excellent article on DEP.
Whie it will show you how to turn DEP on, it will also take you to the control panel that will aloow you to adjust your settings.
http://windowshelp.microsoft.com/Windows/en-US/help/1d9bb9b4-f6ba-466d-ac2b-7b8c4f8361611033.mspx
Oct 03, 2009 | Computers & Internet
Why do i keep getting DEP error message each time i close IE8 or a tab?
windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
http://www.zensoftware.co.uk/kb/article.aspx?id=10002
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
May 10, 2009 | Microsoft Internet Explorer 8
I can't search the internet...closes the program..
unplug your modem, shut down the computer and then try that
Dec 15, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
