Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Heter goin off and on
The flame will come on for 2 to 3 minutes and then turns off
    Genius:
  • 1,199 Answers
Sounds like the thermastat may need replaced
Hopes this helps!
Posted on Dec 15, 2008
Water heater pilot light keeps goin out when i release gas valve button during pilot lighting process.. Ive repeated 5 times waitin 10mins in between but the samething keeps happening.... Any...
There is usually a thermocouple switch which produces a minute current to keep the pilot flame switched on after the button is released. You would need to have a gas plumber look at it. Col
Jan 25, 2018 | Water Water Heaters
Heter trys to ignite,replaced igniter,cleaned fuel filter
1. Check the ignition transformer. It may be grounded,
or it could be defective, and need to be replaced.
2. You have already replace the igniter and the
photoeye.
3. Once the ignition transformer works, everything will
be alright.
May this tip help you.
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
Same Problem how do you replace or check sensor
The flame sensor is easly replaced, but easier to just clean. Only use steel wool never sand paper to clean a flame sensor. Post the exact model and I will publish the manual on my company website and post the link for you to download, print, etc.
Jun 22, 2009 | Pentair Minimax NT Heater
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Nov 19, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool ggw9250pwg
Is there an issue of goin to or from LP (propane) to Natural Gas?? The orfice and metering screw on the valve will need to be adjusted.
Jan 13, 2008 | Whirlpool GGW9250PL Gas Dryer
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
