I M USING THE FACTORY STEREO WITH THIS KENWOOD AMP AND THE SPEAKERS SOUND LIKE CRAP.I PUT THE 2 POSITIVE ON ONE TERMINAL AND THE 2 NEGATIVES ON THE OTHER TERMINAL IS THIS CORRECT?
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
SOURCE: kenwood kac9152d bridge mono wiring diagram
I have owned this amp for 2 years and i have it up to my kicker L5 sub, in a 3.1 cubic foot ported and chambered box that is tuned to 33hz. the amp can be wiried for eitherrunning one sub or several subs, rms power is 500 watt @ 4ohm, 900 watt @ 2ohm, and 1600 @ 1ohm. it is a strong amp, and it puts out large and powerfull amounts of energy, the bass remote is an added touch, i had it set to 100hz on the amp at +1 on the input sensativity, i ran my sub hard producing 138.40 db on a term lab. and i only had the remote at +9/+11 for level and set to 43hz on frequency boost, if you have only one sub with single 4ohm voice coil run it on the outer sides of the speaker outputs on the amp, if you have a dual or quad voice coil, you can either lower the ohms wiring the sub in a paralelle circuit, or up the ohms by wiring the sub in a series circuit. if you have 2 or more subs, wire them left and right channel, the amp has 2 out puts because it is a dual monular amplifier, meaning you can link 2 or more amps together to wire one or multiple subs, witch makes this amp perfect if you have a 180db, @ 18hz **** , than this amp is for you!!!!!! if you need more advise on the amp or how much power it needs to run it or when the amp loads into protection mode feel free to email me @ [email protected]
