Question about SanDisk Sansa Clip MP3 Player
I loaded my music but it skips (cuts in/out) as does FM radio.
What do I need to do to make my Sansa Fuze 4 gig play radio and music without jumping/ skipping?
  • 8,596 Answers
Make sure the songs are in the correct format - WMA or Mp3.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Sansa fuze 8g subcriptions have expired
possible that the format that was loaded is not recognised in your PC. Load your PC with the format required if the file is playing in the player.
Oct 22, 2011 | SanDisk Sansa Fuze MP3 Player
I recently purchased a Sansa Clip MP3. I downloaded audiobooks to it but they will not play. What do I need to do?
Not true!!! The Sansa Clip is actually the best mp3 player I have found for listing to audiobooks. Here is what you need to do. Download the latest firmware update on the Sandisk website. You must do this or it just won't work unless you are downloading books from Audible.
I use the Overdrive Media Console and download mp3 and WMA books from my state library. When you hit transfer, be sure it hit advanced options. Browse until you select the audiobook folder on your player. Then transfer to that.
The player will bookmark your last place on anything that is in your audiobook folder. You can easily switch back and forth between your music and book without losing your place! Love it!
It even has a sleep timer on it. I'm in heaven.
Apr 27, 2010 | SanDisk Sansa Clip MP3 Player
I have a sansa fuze mp3 player and no user instructions
the menu has these function but you can download most of them from they site
Dec 06, 2009 | SanDisk Sansa Fuze MP3 Player
How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Jul 22, 2009 | Audio Players & Recorders
I have a sansa fuze 8 gigs, FAT is corrupted, can it be fixed?
Hi, dont worry your player is probably fine, you just need to refomatt it. Checked out the sanza forum and they were pretty helpful
This guide should be useful
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=11867
Jul 20, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze skips songs
Same problem with my sansa fuze 8 gig It skips over songs instead of playing them.
Mar 25, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 4 g photos wont open
Get "Sansa Media Converter" from the Sansa website or the CD that came with you Fuze.
If you are not using the "Sansa Media Converter" program to convert the photos to a format the Fuze can display, they will not show up.
Nov 07, 2008 | SanDisk Sansa Fuze MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
145 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
