Question about Toshiba 57H81 57" Rear Projection Television
Toshiba model 57H81
Do you have a toshiba part # for the HYper board? What is the full name of this PCB? Thanks, Ed Wilson
I turned the tv on for about 20min and it started to have 2 lines up and down and it started to get snowey and then the picture went out
Posted on Jan 30, 2009
Replaced 11 caps on Hyper board and it fixed the problem.
Posted on Oct 09, 2007
  • 81 Answers
Hyper board is not longer avable replace all 10 10uf capss inside will fixit.
Posted on Apr 05, 2007
Hyper board is nat made anymoore just replaced 10 10uf caps inside.
Posted on Apr 04, 2007
Toshiba hyper module. Vertical lines on screen.
change the 10 or so surface mounted bad filter caps in the Hyper module this set uses--the board is no longer available--it can be sent out for rebuild (not toshiba) but that is rather costly (200+)
Oct 28, 2012 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 location of vidio baord
yes they are bad, they are surface mount on the digital board. Board replacement is advised. They are not easy to change if trying to replace the capacitors.
Dec 08, 2007 | Toshiba 57H81 57" Rear Projection...
What would cause a projection screen tv (toshiba) to have to warm up when turned on? the picture flutters and is unviewable for 6 to 7 minutes
The Hyper module needs replacement. There were repair kits available for the hyper boards several years back the capacitors ( surface mount) need replacement
Jul 01, 2011 | Toshiba 57H81 57" Rear Projection...
RE: TOSHIBA 57 IN
This is a Hyper PCB problem. Ready the following for information: http://www.hdtvoice.com/voice/showthread.php?t=10984
Mar 27, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Image Problems
This is a common fail for a Toshiba 57H81 the cause most likley is caused by the Hyper board, there are several capacitors that have weakened and need to be replaced, these are surface mounted and have VERY Fragile contact points, if your soldering skills are week you might want to take this somwhere to have it fixed
Dec 26, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Image issues!
I am thinking surface mount caps on the Hyper board. That should definately be serviced by someone experienced with Toshiba Hyper boards.
Jul 02, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Mar 19, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81Problems Please Help
On this model I've found the hyper module to cause lines (Left to right) in the picture. Usually at start up and half the screen, then after warm up, the set will clear up some or completely. Of course a picture of the problem would help in diagnostics. The hyper module must be soldered in, so, knowledge of soldering is advised. This PCB can be bought at: Andrews Electroncis or Tritronics. I do this job in the home, pick up for service should not be required.
Jan 06, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
759 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
