Question about Samsung YP-T10 Digital Media Player
Yp t10 will not turn off
I tried holding down the button resetting it and everything but the power button refuses to work
  • langleypark0 Feb 01, 2009
    Thanks for the help but i just called samsung to get it repaired so hopefully it wont happen again.
Not as simple a solution as the other solution. I was going to click "I have the same problem" after spending hours cruising around.
As I started to type, I knocked the T10 (which had turned itself on by itself minutes before) onto the hardwood floor. It immediately went off. It has stayed off.
I turned it on, listened to a song and shut it off and it has not come back on.
I noted that the switch seems to "feel" different. It was kind of slithery before, very soft, whether going up to lock or down to go on or off. It now feels more crisp to me.
I wonder if the issue can just be a less than acceptable switch?
tnx
solentstay
Posted on Dec 28, 2008
All you have to do is go to setting, then go to system and then go to auto power off. it is probably selected on "always on" thats y u cant turn it off change it and it shud b fine!
Posted on Dec 26, 2008
My YP-T10 sliding power switch feels looser. Sometimes when I turn it on the touchscreen buttons won't work as if it were on hold, and when it does work sometimes it turns of randomly if I don't put it on...
Hi, not a solution but that is exactly what is happening to my T10 as well. It just started working this way yesterday and I don't know how to fix it. When I want to change a song, I have to slide the power switch so that I'm nearly turning it off to change a song. As well as that, I can see the 'lock' symbol on my screen even when I don't put my T10 on hold. Someone please help?
Jan 31, 2011 | Samsung YP-T10 Digital Media Player
It doesnt work at all!!!!!!
hardware problem or the battery couldve died on you (literally)
Jun 29, 2009 | Samsung YP-T10 Digital Media Player
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
MP3 Samsung YP-T10 playing songs too fast
Turn on your T10, click any song and touch the third button on the top row (button that is a box with two lines in the middle). then move down to play speed. Then make sure it is on 1.0. :D
Oct 08, 2008 | Samsung YP-T10 Digital Media Player
The heat sensors in my yp-t10 don't work
Resetting the player to its factory settings (there's an option to do that in the settings section) should fix your problem. Unfortunately, you will have to re-sync all media on the player, as the reset will delete all data. if this doesn't fix it, i would recommend a call to the manufacturer or a trip to the store where you bought the player.
Aug 22, 2008 | Samsung YP-T10 Digital Media Player
My t10 has locked up!
Reset is a better alternative....
How Do I Reset The YP-T9?
spacer.gif To reset the YP-T9:
  1. Turn the power on.
  2. Press and hold both the [MENU] button and the [A/B] Button. The device will turn off.
Here is a useful link:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=01010100&subtype=&subtype_cd=&model_nm=&dType=S&vType=L&mType=&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-T10JAB&menu=main&isEqualsY=Y
Jun 13, 2008 | Audio Players & Recorders
What do i do??
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 14, 2008 | Samsung YP-T10 Digital Media Player
Hi my yp-t10 2GB can't be switched on
There is one last ditch method, but this is most likely a hardware issue that cannot be resolved without replacement:
Apr 22, 2008 | Samsung YP-T10 Digital Media Player
Samsung YP-T10 Digital Media Player Logo
146 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
