Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Water on the bottom of the fridge - then turning in ice
I have a four year old Hotpoint FFA60 Fridge Freezer. It was working fine until recently when there was water at the botttom of the fridge. This then leaks into the freezer section and also ices up on the 'floor' of the fridge. The 'drain' plug seems blocked but I cannot find any blockage. I have removed the drain pan and emptied it of water. Any suggestions would be welcome!!
  • johnyq Jan 14, 2008
    Hotpoint Ice Diamond drain hole blocked in top fridge. Have tried to push wire down hole but is not accepting wire. Hole seem to have a plastic insert in it so that wire does not enter straight down?
  • Anonymous Sep 01, 2008
    freezer ices up
    President:
  • 1,462 Answers
Drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Posted on Mar 20, 2007
Hotpoint fridge ffa60 red light on not sure what to do
fridge is freezing but freezer isnt how can i set my tempature
May 28, 2012 | Hotpoint FFA60 Bottom Freezer Refrigerator
My hotpoint frost free, fridge compartment keeps collecting water at the bottom of the fridge. I've checked drain hole is clear of any bits. The temperature strip in fridge is constantly black and ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Ffa97g/frostfree
remove back panel inside freezer and you will find drain at bottom blocked with ice. melt off with a hairdryer and follow up with hot water till drain flows freely.
you may have a fault with the defrost system or the drain heater
Sep 09, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Dec 10, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
1,073 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
