Question about Jandy Aqualink - Rs32 One Touch Pool / Spa Combination Control System
Incorrect JVA settings
When the freeze protect is activated the system cycles to spa mode and then the spa drains to pool which then overflows. I believe my jva is assigned incorrectly and moves to spa drain when reading spa mode. I currently have set system to service mode and am running all pumps (4) to prevent freezing. My question is how do I verify and set jva to correct position?
  • John May Dec 15, 2008
    I have consulted the manual for the one touch and it is not very specific as to the proper procedure. I believe I have the valves in the proper positions now and have the system in service mode so hopefully the valves will not rotate. What I need to know is to set them to stay where in the position they currently are in do I set it as pool mode? Then do I manually change them to say for instance to clean mode and then set the system? Does the system accept the current location as the default location for the mode that is being entered?
  • 479 Answers
just click this link for all information.
Posted on Dec 15, 2008
  • tech gurus Dec 15, 2008
    yes will have to change it manually and then set the system.
My spa is draining into the pool when I put the blower and heater on.How do I stop it?
you have to go into set up sounds like your acuator for spa is highlighted with the aux that your blower is set on uncheck it from that aux also check jva assignment if you need more info please email me
Jun 19, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Show me the pump valve for the hot tub jandy
go to system setup then go to jva set up activate in and out then make sure JVAs are on
Jul 31, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have a Jandy 2440, water level decreases in spa mode
Probally your return JVA is not turning all the way. If it was going down fast that would mean not turning at all and you would probally need a new JVA. Not getting all the way around means the cam has probally slipped. If you have a book (more of a pamphlet) on the JVA it can walk you through adjusting the valve. It is worth it it comes with pictures.
Pull the handle and remove the top of the JVA by removing the six small screws. Once it is open than you can loosten the set nut on the shaft and adjust the valve to the full spa position. The cam on the shaft will need to be set so that the valve goes off when it reaches this position then you will need to tighten the set screw again. Run the valve a few times to be sure it stops when it should. If you have it set then go ahead and put the top back on. I hope this helps, good luck.
Mar 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool will sporatically alternate between spa and pool mode. The JVA valves will at like they are confused and move back and forth even though the pool was completely off
You need to check and see how many different programs you have set in the control. If you change a program or add one the old one stays and will cycle and override any others that are in the system. You probally need to remove any old programs in the system. The valves running after the system is off is probally the system reseting. You would probally do best to clear the whole system and start new. Good luck.
Feb 26, 2010 | Jandy AquaLink RS2/6 All Button Dual...
JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Jan 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I do have a problem with Jandy Aqualink System
I would lower the freeze setting. It sound slike you are hovering around the temp set for freeze and that is why it is turning on/off. Go into the freeze mode settings and lower it as you would a heater setting.
Dec 28, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs32 One Touch Pool / Spa Combination Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
