Question about Dell Optiplex GX280 (99301) Motherboard
GX280 - is it the motherboard?
Hi - I have a Dell GX280 which has the loud fan issue..
I have replaced and upgraded the original heatsink w4254 to the G8113 and replaced the original fan w/ same model.
The fan is still running at a high speed - w/an above normal noise...
Do you have any suggestions on how to fix this... could it the motherboard? if so - do you know what dell replaced the problem boards w? (i.e. model #) I also did a bios flash today A03 to A07... :-0 but the fan is still not very quiet... your suggestions would be greatly appreciated.
  • esrarazvi Dec 17, 2008
    Its the capacitors on the motherboards. Dude we will be trying to fix it. If it works we will let you know if we can sell it to u for a decent price or unless u can solder but if you cn't then please dont try. My email is so get in touch with me in about 1 week. Happy holidays
  • cnmoua Feb 21, 2009
    I have the same problem. Please tell me if there is any possible solution.
Try to press down on the hood of the cpu fan and see if it reduces speed and noise..
Posted on Jun 15, 2010
I had the same problem and now it is resolved.
Posted on Mar 17, 2009
  • 60 Answers
Go here and download this program.
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Posted on Jan 10, 2009
Dell optiplex GX280, beep one long, follow by 3 more beeps, then two more.
This is a motherboard problem, if the video Graphics Card is a plug in remove it and test as you go, unplug hard drive, and any other hardware, if at the end of it no change, motherboard will more than likely need to be replaced.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Hello, I've got a Dell Optiplex GX280 series desktop pc which has refused to boot up. Instead it shows an error saying "Alert! chipset heat sink not detected system halted! Would appreciate your...
Both your CPU and chipset have heatsinks to dissipate the heat they generate.
Over times, the heatsink compound between these components and the heatsinks
may dry up and no longer conducts heat efficiently. Your system on power up,
detects excessive heat from the chipset and if allowed to continue on, will burn
itself up. To protect it, your system shuts itself down.
Open up your case and inspect the chipset. Make sure the fan (if any) is running.
If it is, you may have to remove the heatsink (normally clipped on to the chipset)
and remove the old compound and apply a fresh new layer of heatsink grease.
While you are at it, also replace the heatsink compound of your CPU.
Jul 11, 2011 | Dell Optiplex GX280 (99301) Motherboard
Hd keeps rebooting. I swapped drives, battery, memory and still the same so it must be something with the motherboard. Any suggestion. It's a Dell Optiplex GX280 desktop
It could also be the processor, either its overheating or it has simply packed up first check that the heatsink above it has been correctly installed and is resting directly on top of the processor and that the fan on the heatsink is functioning. If that doesnt work then replace the processor completely.
Jul 15, 2010 | Dell Optiplex GX280 (99301) Motherboard
I have dell optiplex GX280 System in unbranded casing, Kindly suggestion about Processor Fan Voice, he is so shouting
The fan(which runs on a bearing) has aged, it must be replaced. Luckily this is an easy and cheap fix. Pick one
May 30, 2010 | Dell Optiplex GX280 (99301) Motherboard
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
I have a dell optiplex gx280 which seems to have a racing fan problem. sounds pretty loud, and varies. any ideas?
The fan bearings may be going bad. Variable speeds are normal as the fan adjusts to the cooling requirements.
Oct 24, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computer freezes up. Only unplug power cord can I reboot the computer.
  1. Dell suggests upgrading audio drivers and flashing bios.
  2. I did both of these and problem reappeared after a while.
  3. Then I removed heatsink/fan assembly,cleaned all surfaces,applied good quality silver-loaded heatsink compound and reassembled
  4. PC has been running for more than a day with no probs so far
Feb 12, 2008 | Dell OptiPlex GX280 PC Desktop
Dell GX280 no display
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
2,429 people viewed this question
Alun Cox
