Question about Master Bilt Commercial Freezer DD-66CG
Dipping cabinet will not reach temp. ice cream too soft.
The unit never cycles runs continuious.
  • mmcintosh718 Apr 23, 2009
    my freezer is icing heavily. It is a dipping freezer
  • Todd Born
    Todd Born May 11, 2010
    has anyone worked on this lately because it may be undercharged.
  • 700 Answers
Is the condenser coil clean on the unit?
Posted on Mar 25, 2009
Ice Cream Dipping cabinet running but not working?!
Ice cream needs to be below 0 degrees. It sounds like you have a refrigeration problem. The unit runs constantly because the temperature control is never satisfied. ;)
Jul 13, 2009 | Freezers
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Bed room door locked
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Feb 18, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Master Bilt Commercial Freezer DD-66CG Logo
191 people viewed this question
Top Master Bilt Freezers Experts
Dennis Boxerman
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you a Master Bilt Freezer Expert? Answer questions, earn points and help others
