Question about Linksys Wireless-G WRT54GS Router (e125894)
Changing the NAT typer from "moderate" to "open"
How do we do it
    Genius:
  • 1,061 Answers
Follow these steps to use this solution:
  1. Use the no ip nat {inside | outside}command to disable future translations from taking place.
  2. Use the clear ip nat translation command to clear IP NAT translations.
  3. Change the NAT configuration.
  4. Restore the NAT {inside | outside} arguments with the ip nat {inside | outside} configuration command.RICHARDM69
Posted on Dec 16, 2008
3 Suggested Answers
  • 71 Answers
SOURCE: Halo 3
make sure the security settings on router is WEP-Personal. I don't know what you have for internet but Dial-up, DSL, and satellite internet will not get NAT 1.
Posted on Mar 15, 2009
I went on a trip and connected to a network with a moderate NAT type. When I got home I tried to connect back to my original network which is usually open and it didn't switch back to open. I connect using...
var YAHOO = {'Shortcuts' : {}}; if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts '' {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = ""; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "ross.haller@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.version = "2.10.0"; YAHOO.Shortcuts.annotationSet = { "lw_1299607050_0": { "text": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "extended": 0, "startchar": 286, "endchar": 363, "start": 286, "end": 363, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "capAbtScore": 0, "abtScore": 0, "csScore": 0, "prismaScore": 0, "spectrumResolutionScore": 0, "conceptScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "metaData": { "linkHref": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.annotationSetID = "1eac068650c8d27415163f15165866e5"; http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360
This is what I did.
Feb 19, 2011 | Microsoft Xbox 360 Console
Tip
Xbox live NAT
Simple Rules
-if your NAt is strict and cannot connect
try turning your hub off for 30 seconds then turning it back on
if that didnt work.
-try resetting your IP address.
if that didnt work
-take addaptor from xbox to pc out for 30 seconds, then put it back in
if that didnt work
- try opening thies ports
TCP 53
UDP 53
TCP 80
UDP 88
UDP 3074
TCP 3074
Helpfull Info
Sometimes depending on the router brand, it's not possible to open your NAT, this simpily becuase some are not specificly designed for Xbox Live purposes. A good example of this is Belkin routers. These brands are most commonly made for Buissness connection servers. If you are experiencing a STRICT/MODERATE Nat with a Belkin router, the chances are you are going to have to deal with it, but that is not 100% of the time. If you've have attempted several techniques to open your Nat and the changes arnt happening, i'd recommend a 'N' powerd Belkin router, the most majority of these routers work 100% perect for Xbox Live, I myself oned one but changed due to a broadband switch.
How do I change the NAT firewall protection? (Open/Moderate/Strict)
Find your IP address number then type it in on your web browser, this will bring up all your switchable options where several options can be changed to your approval. The NAT firewall is one of these options which can be changed. (like I mentioned before, if you own a Belkin router, the chances are even after changing the fireall level, it will turn back to moderate or strict)
on Feb 17, 2010 | Computers & Internet
I went on a trip and brought my console and connecetd to a network with a moderate NAT type. When I tried to connect to my original network which usually has an open NAT type it would not switch to open...
Thats odd I know I have a moderate because I'm using a wireless 360 network adapter and my brother has open as he uses a ethernet cable. Also maybe if your bro unhooks his maybe yours will be open and his will go to moderate.
Feb 18, 2011 | Microsoft Xbox 360 Console
I want to change my NAT setting from moderate to open
OL, you need to get the manual, link below, and it is all in there how to do it, in security section. NAT = Network Address Translation.
ec1.images-amazon.com/media/i3d/01/.../MANUAL000000300.pdf
May 20, 2010 | Linksys Wireless-G WRT54G Router
How can i make my NAT open from moderate??? (xbox live)
TO opennthe NAT in your router. you willl need to make some changes on your router.
You will need to reduce the MTU on the router to 1365.
you will need to disable the firewalls on the router.
There are some port numbers that you will also need to open on the router.
For this you will need to open the set up page of the router.
Click Here for more info
Oct 17, 2009 | Zyxel P660HW-D1 Router
Halo 3
Mar 14, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Nat
First call microsoft and tell them that your nat is moderate. (for me it still works on moderate...???) Tell them your router and internet service provider. They will tell you a port number which will have to be opened in order to make your connection stronger. then call your router manufacturer. (or vonage) And they have to help you.
Mar 24, 2008 | Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
2,104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
