Question about Panasonic TH-37PA20U/P 37 in. Plasma Television
My t.v screen is fuzzy and the picture is showing double on one side and it at times seem s streched
The stretching might be due to having the wrong aspect size on your tv. Look on your remote and see if you have a button that says "Aspect" or it could say "ratio" or something to that effect. You can cycle through the different screen sizes to make it not appear to be stretched. As far as your picture being fuzzy, if you are using a standard antenna that may be the cause. If you are using cable, I would contact the cable company and have someone come out and check your signal strength, and possible inquire if you need a cable booster added. If you are running cable through a cable box and are running it straight coaxle then I would recommend trying a different hookup method, e.g Red, white yellow cables, or S-video or even hdmi, whichever your cable/satellite box and tv allows.
Posted on Dec 15, 2008
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
Vgn ar630e fuzzy screen
Hook a spare monitor to the video output usually on the back, if picture okay! the LCD screen will need to be replaced on the laptop, but if both show the same symptom it is the Video Graphics Card normally built into the motherboard.
Mar 31, 2012 | Sony VAIO Digital Studio VGN-AR320E...
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My kids were playing with the buttons on the tv, and itseems like the picture is now "stretched" vertically - the tops of heads are cut off, and it seems like some of the picture is missing from the sides....
there should be a zoom, or strech, or even the letterbox option somewhere. What your describing is a enlarged picture that doesn't fir the screen, like if I select zoom on my remote.
Dec 10, 2009 | JVC AV-36D302 36" TV
Fuzzy pics
Go into your camera. At the bottom of the screen, on the right side, the word options shows. Press the blue dot below it and set the effects for whatever you want.
May 22, 2009 | Motorola Mobility W375 Cellular Phone
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
TXJ2066 Samsung
  • your problem is due to crt getting weak
  • because of that you are getting fuzzy picture.
  • good luck.
Oct 23, 2007 | LG 30FS1D TV
Streched screeen!
I see more of this out in the field everyday. If you have a cable box or satelite receiver, then look for a format change on it. Usually in that components menu. If, you still cannot find the answer, reply back with the type of unit, if any, that control the channel on the set. I hope this helps.
Jan 12, 2007 | Hitachi C29-F800S 29" TV
Panasonic TH-37PA20U/P 37 in. Plasma Television Logo
506 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
