Question about Refrigerators
Water leaking from under fridge
I checked the drain pan in back but it was bone dry it seems water will leak out on the freezer side. The seal is good on the freezer side. Why?
Check to see if you have a crack in the water line running to the ice maker. The plastic line is prone to crack. Easy way to see if water is from ice maker is to shut off water to it (usually under sink).
Posted on Dec 15, 2008
How do I fix water leak from the Kenmore Coldspot side-by-side refrigerator
I would say or ask how is ur defrost timer working as this seems to indicate that ur build up of ice is more than normal hence u have more water build up that should usually be evaporating from the compressor heat and ur drain pan should not be so full. some other things to consider are below:
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
u can test the defrost timer as well
May 06, 2015 | Kenmore Refrigerators
Water leaking out of bottom of freezer water line not connected
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore Fridge: 44103 side by side: I keep finding a
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
Leaks water in the refrigerator down the back under
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
My fridge leakes water?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Frigidaire FRS26R4A Side by Side...
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
