Question about Canon DR-5020 Path-Through Scanner
DR-5020 I installed a new upper reading unit but am unable to adjust the brightness and when you OCR it lightens the copy. I contacted Canon and was told that something needs to be reset but they would not be spicific and to call a local tech. Any help on what to do would be appreciated. Joluby@comcast.net
    Genius:
  • 1,199 Answers
In the upper reading unit there might be a reset button (very small) this is only on so,e units
Posted on Dec 15, 2008
  • Canon Master
  • 19,396 Answers
You need to enter in service mode and set brightness, I see if I can find the procedure.
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/.../psp-406.html
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/.../Dg-c_intensity.html
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
ugp01.c-ij.com/ij/webmanual/ScanGear/M/MFP/19.1/.../Sg-930.html
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
Lower reading unit broken?
Ensure you have selected Duplex option. Canon DR 9080C uses LED lights and hence the chances of failure of light source is fairly low. Try scanning in Color.
The scan module, if required, can be replaced and is available in the market between $600 to $750. Please ensure that the module is faulty before replacing. (the upper and lower modules are interchangeable, except for a few plastic parts)S. Mohan, Chennai, India
Feb 24, 2012 | Canon DR-9080C Path-Through Scanner
Can not install canon dr=5020 scanner/ installed scsi card then went to canon's site and downlaoded drivers for windows xp-computer asks to add hardward but does not find an "inf" file in the 6...
First ensure that the SCSI card is installed properly. Download DR 5020 drivers from http://software.canon-europe.com/products/0000672.asp and install them. Use CapturePerfect ver 2 or 3 to scan documents. With SCSI based scanners/devices, one should power-on SCSI device first before starting the Computer.
Feb 17, 2011 | Canon DR-5020 Path-Through Scanner
DR-5020 Path-Through Scanner: can't fing the drivers for the canon dr5020 scanne...
You can down load drivers from Canon Europe site. http://software.canon-europe.com/products/0000672.asp
S. Mohan
May 18, 2010 | Canon DR-5020 Path-Through Scanner
ADAPTEC 2940 SCSI CARD WILL NOT RECOGNIZE CANON DR-5020 SCANNER
. Have you installed DEvice Driver? Download item no 5. in this link http://software.canon-europe.com/products/0000672.asp
This should solve your problem.
Apr 02, 2009 | Adaptec 2940UZW ULTRA WIDE SCSI PCI...
Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
Canon DR-5020 Path-Through Scanner Logo
old marine
old marine
