Question about Frigidaire GLTF1670A Front Load Washer
Softener cups are filled with standing water after wash cycle
I have a frigidaire front loading washer that that 3 slots for detergent, brightener and softener. Lately, once the wash cycle is finished, there is standing water in the brightener and softener slots. What is the problem?
  • 2 more comments
  • dlsipe01 Dec 20, 2008
    I have the same thing going on. Its only one month old and didn't do it for the first 2 weeks.
  • rattierescue Jan 14, 2009
    Bleach and softener filled with water in mine, makes it so I can't fill them with the bleach as needed. Unknown why it's happening.
  • Anonymous Jan 24, 2009
    I have the same problem too. have had the machine for a year. i've just ignored it, and put product in on top.
  • Anonymous Feb 11, 2009
    I HAVE THE SAME PROBLEM. WE JUST ADD WATER TO THE SOFTENER CUP AND IT WILL FORCE SOFTENER INTO THE MACHINE, THEREBY KEEPING THE CUP CLEAN. I HAVEN'T HEARD OF ANY SOLUTIONS , BUT WOULD LIKE TO KNOW OF ONE. OTHERWISE MACHINE IS FINE.
  • 249 Answers
SOURCE: Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Posted on Nov 25, 2007
  • 220 Answers
SOURCE: fabric softener dispenser won't drain the fabric softener.
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Posted on Jan 16, 2009
localwonder
  • 6784 Answers
SOURCE: front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Posted on Mar 22, 2009
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
SallyUK
  • 9 Answers
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
Posted on Jun 16, 2009
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My clothes never have a good smell or at best any smell recently. I also never see the water stay in the washing and it suds up like it used to. It appears that when the water is being put in, it is going...
Try this. Run a load of a few towels with no soap, no bleach, no fabric softeners. Set wash water temp to hot. After hot water enters and begins to wash, stop the washer and open the door. Pour in one cup of vinegar (white is fine.) Run the entire wash cycle.
-Buy a supply of High Efficiency Washing detergent (marked "HE") and do not over fill the detergent cup (use a little less than the directions say, never more.)
-Buy a name brand supply of fabric softener with a scent you enjoy and can recognize.
Run the next weeks loads of wash (no need to use Hot water any more) and report back here with how things are smelling. OK?
Aug 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
LG Front Loading Washing Machine
Bleach goes in on a calculated time.Yes some one could have reversed lines.Actually the harness i believe.
Jun 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
