Question about Linksys Wireless-G WRT54G Router
Your solution Just wanted to drop a line and say thanks for your help! It worked! You saved me alot of time, energy, and patience. Again, thank you for your quick response and tip. Princess
  • 120 Answers
Glad I could be of assistance. Happy holidays.
Posted on Dec 16, 2008
WANT TO ADD PICTURE TO FAVORITES
Hello Norman,
To add a picture to Favourites
  • 1
    From Start, press Pictures.
  • 2
    In Pictures, find a picture and press to open it.
  • 3
    Do one of the following:
    • • If the picture is already saved on your phone, press Morebasic-icon-ellipses.png and then press Add to favourites.
    • • If the picture is in an online album, press Morebasic-icon-ellipses.png and then press Save to phone. Go to Albums > Saved Pictures and open the picture and then press Morebasic-icon-ellipses.png > Add to favourites
    • Please rate me if you like my answer that helps me alot.
      Thanks.
Apr 19, 2012 | Acer Computers & Internet
Tip
You da man, er, Guru! THANKS for the Very Easy Step-by-Step Instructions on the...
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Feb 21, 2011 | Hoover V1 SteamVac SpinScrub Vacuum
Replace front wheel studs
Usual all u need to do is: find a nut (no the lug that came off) and hit the old one out. You will need alot off wd-40 and patience. It's not that easy. Once u get the ones u want to replace off, take the new ones, put them in slot. Try to by hand really work them in. They are groved so you want to make sure to get them somewhat in by hand. You won't be able to get it all the way in tho. Now take one of the lug nuts, and a thick washer or two and run it down by hand. With a ratchet or breaker bar, slowly tighten the new ones down till there flush in back. This will take alot of muscle and patience. You don't want to force it and have to do it all over again. Once there all down and flush in back that's it, your done and you can put the tire back on. Like I said time and patience dont rush it. Other than that it's very simple. Hope this helped
Mar 29, 2011 | 2000 Kia Sephia
I want more money and energies...........and goods
hi! Please be specific on what games you wanted more money, energies and goods so that I could properly help you with it. Thanks! In the meantime, most games usually requires time to replenish energy, you can't do anything about it because it is programmed that way.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Facebook Apps
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
When we are not using the printer for a long time, roughly 1 hour, the CPU Displays "Printer in Energy Saver Mode". how to activate as a Printable mode, the way we are doing is just restart the...
Dear vasanth, stand in front of the machine look at the right side, there will be a light green button
(small) if you press it the printer goes to energy save mode, again you press it, it comes to printable mode, no need to restart. if doubt persist call 9841315555(chennai)
Jan 17, 2011 | Xerox DocuColor 12 Printer
HP Pavilion dv1000 laptop turn off suddenly and cpu fan is working ok. after goes off is hard turn on again, not is battery neither ac adapter but i have seen that many people has the same kind of problem,...
If this happens while you are using it, then that's one thing.
We will get to that later.
If it happens while the unit is just sitting there, then that's another thing.
You probably have an energy savings setting problem that you can easily resolve simply by going into the My Computer equivalent and reconfiguring your length of time prior to shutdown of either the display and/or the hard drive.
Find the "DISPLAY" Icon and click on it and you will find a variety of energy saving routines which you can set to the amount of time that the unit will stay on, even though not in use, after which it will shut down to save energy and wear and tear on your components.
Now, as promised, if this occurs while your unit is in use and just shuts down while you are typing, then your unit requires service by a professional as there apparently is some kind of shortage which with further use could damage your unit.
I hope this helps, but if you have further questions, feel free to ask.
Apr 22, 2009 | HP Pavilion dv1000 Notebook
Smelly washer
there is a washer cleaner from whirlpool Affresh works good
Oct 11, 2008 | GE Energy Star WCVH6260F Front Load Washer
Syncmaster 171s keeps blacking out.
video card may not be able to keep up with the page or the monitor is set to th wrong resolution on the display settings
Apr 29, 2008 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
