Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machines element
How do you remove/replace the element in a bosch washing machine? there doesn't seem to be an obvious fixing
  • Peter84 Aug 30, 2008
    It would be really hepful to clarify this solution. I want to remove the element from my Bosch WFF147S (similar to 140L 1401 1301 1201 1101) so that I can use the hole to look for a trapped item - seems to be in the concavity behind the drum.
    Does the element simply prise out from behind - or do I need to get at a nut or anything inside the tub. I don't want to start something I'll regret!
  • Anonymous Mar 26, 2014
    I can't locate the heating element to replace it
Depends on model. most washer elements are fixed by a centre nut (10mm)which undo and then prize out the element - takes 5 mins
Posted on Mar 19, 2007
How to fit bearings in wfl 2260 bosch max washing machine
dose drum has to come out also replace element
Mar 02, 2015 | Bosch Washing Machines
How to fit element in bosch washing machine wfl2067gb/01
You need to remove the front panel locate element under the drum
loosen screws but don't remove them
push them back in and remove wires
slide element out
Aug 20, 2014 | Bosch Washing Machines
Bosch maxx 900 manual
It could be caused by a damaged heater element.. remove and check for damage. One way to check is to remove the two wires and tape up to prevent accidental short circuit. set machine to a cold wash if it does not trip you know what you have to replace. if it still trips then remove the motor and check carbons/ brushes for excessive wear. good luck..
May 10, 2014 | Washing Machines
How to take the front off a Bosch WAE24260GB washer
Take the top of the washer off. There are 4 screws in the panel and 2 on the front - inside
Feb 21, 2014 | Washing Machines
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Excell washing machine programme fault
Jun 28, 2009 | Bosch Washing Machines
Element Needs changing Bosch WFO2466
you should never have to remove drum to replace element. not familiar with this machine take back off and have a look or it will be at the front of machine
Jun 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine
There are 2 ways: 1. Tip machine on its back and remove the sump hose from the bottom of the tub, and root around inside. This option doesn't give you much play. 2. Remove the from of the machine and the heater element. 1. remove soap drawer and undo resessed screw 2. remove kick strip and remove screws behind it 3. remove door seal band and front of door seal 4. slide front panel down and towards you to remove. 5. remove heater element to gain access to inner drum. With the sump hose also off you should be able to remove the foreign object. http://www.ransomspares.co.uk/bosch-washing-machine-spares.html
Mar 01, 2007 | Bosch Classixx WFO 2866 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
164 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
