I would check the power cable to ensure that nothing is broken. Then get your multimeter out and check to ensure that you are receiving 12-14.4 VDC to the plug that is inserted into the player. If both of those check out then you know it is the player itself. If you determine that it is the player, then you will need to open it up. Chances are that one of the capacitors have failed. You can normally tell because the case is swollen or leaking. If this is the case then you only need buy another cap and then replace it if you know how to solder.
SOURCE: replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
SOURCE: i have a 9"durabrand portable
You can buy an ac power charger adapter for your Durabrand PDV-709 here:
SOURCE: PORTABLE dvd player
click on hyperlink
buy replacement ac power adapter Durabrand PDV709 tad10 tad-10 charger
SOURCE: Need AC Adapter #PA009UG01
click on hyperlink:
buy replacement ac power charger adapter Audiovox pvs33116
