The power comes on and when i select a cycle and press start it automatically goes to clean washer with 60 minute on the time. it then will beep until i unplug it.
Looks like the Oasis version. Yeah thats a control panel issue. Most likely gonna need to replace it. Its not serviceable part. Pretty expensive. Unfortunatly rather common. The part # is W10034450 . I would suggest calling sears and putting it back under warranty. Even if you didnt buy it there, thell still warranty it. May be little expensive but much cheaper than having someone repair it plus the part cost. Unfortunatly I have seen many computer and panel issues with these machines, and I recommend keeping them under a maintanance agreement. Hate to have to tell you that but thats the best advice I can give you. Looks like the Oasis version. Yeah thats a control panel issue. Most likely gonna need to replace it. Its not serviceable part. Pretty expensive. Unfortunatly rather common. The part # is W10034450 . I would suggest calling sears and putting it back under warranty. Even if you didnt buy it there, thell still warranty it. May be little expensive but much cheaper than having someone repair it plus the part cost. Unfortunatly I have seen many computer and panel issues with these machines, and I recommend keeping them under a maintanance agreement. Hate to have to tell you that but thats the best advice I can give you.
You can't post conmments that contain an email address.
I understand your frustration. It sounds like your GE washing machine is having some problems. Resetting the washer may help to fix the issue. Here are the steps on how to reset a GE washing machine WPDH8900J1WW:
1. Unplug the washer from the power outlet.
2. Wait for 2 minutes.
3. Plug the washer back in.
4. Turn on the washer.
5. Select a cycle and press the start button.
If the washer still does not work, you can try resetting the drum motor. To do this, follow these steps:
2. Wait for 1 minute.
4. Open and close the lid of the washer 6 times within 12 seconds.
5. Close the lid and press the start button.
If the washer still does not work after resetting the drum motor, you may need to contact a qualified appliance repair technician.
Here are some other things you can try before resetting the washer:
* Make sure that the washer is properly leveled.
* Check the water supply hoses for leaks.
* Clean the lint trap.
* Check the detergent dispenser for clogs.
I hope this helps!
"LF" on display (Long Fill - no water or insufficient water supply)
Press POWER/CANCEL to cancel the cycle. Unplug washer or disconnect power.
Plug in washer or reconnect power. Re-select cycle and press START/PAUSE.
"F9E1" on display (Drain Problem)
"SD" on display (Suds Routine)
When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SD" is displayed during rinsing and at the end of the cycle to inform you that the Suds Routine was activated. Use only HE (High Efficiency) detergents.
"F--E--" Variables (Washer Problem)
Press POWER/CANCEL to cancel the cycle. Select RINSE, DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START/PAUSE.
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Hi, Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds. Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared. If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle. After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer. Hope this helps.
is it IE or LE please confirm it.if it is LE code the fixing procedure is given belowThis usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes: 1. Press the power button to turn the washer off. 2. Press the power button to turn the washer back on. 3. Cycle the spin cycle selection to 'no spin'. 4. Press start. The washer should set to one minute, lock the doors, then drain out the excess water. Once the 'End' cycle comes up, unplug the machine for several minutes. Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting. Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
jenkle, F then 1 flashes when there is a primary control failure. There is a couple of things you can try. 1. Unplug the machine for 2 minutes and see if the error returns. If it does, try activating the auto diagnostic mode. With the washer plugged in and all indicator lights off, select any key except power, start and stop. Here's what you do; press/hold for 3 seconds, release for 3 seconds, press/hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds. If you did it right all indicators will light and 88 will appear in the display. If there are any faults, they will then display, look for a F-60 through 68. This will confirm the board is corrupt. If no faults are found the machine will go through a five minute automatic test cycle. To stop the test, just press stop/cancel. Check your owners manual and see how long the board is warranteed. Catriver
Model
110.27072600
Ser
CT2672106
i found these in the lid of the washing machine.
thank you!
