Question about Nokia 6233 Cellular Phone
Swf the and some file don't work ON my nokia 6233
Some swf theme that don't work on my Nokia 6233 is there any way to make it work
pls help cause i'm tired from this problem and I can't find soluition..
thanx for all
  • 1 more comment
  • santoshi_a Jan 20, 2009
    after a firmware update the swf themes are not working in my mobile
  • kalyan27h Jan 30, 2009
    i have the same problem, and other one=  there is a problem to play videos, it not work smoothly .
  • vcsarun991 May 11, 2010
    What is the ram memory speed for Nokia 6233 generally and which size files would be possible to work with?
    Problem Solver:
  • 6 Answers
If the file size bigger than the phone's ram memory ,your mobile is not able to run it.try small memory capacity files.
Posted on Dec 20, 2008
How to open divx movie from my phone ku990r viewty
Step 1: Download the files EFS MediaBuilder and Theme Manager 3.2
Step 2: Run EFS Media Builder, and navigate to "LGAPP/Media/swf/theme". BACKUP "theme_bg2.swf". If you really don't want to **** things up, just backup the whole **** "theme" folder.
Step 3: Choose where you want to install your theme manager
Sep 09, 2011 | LG KU990 Viewty
Unable to open swf files in my mobile N72
By default, N72 does not have an app that will open the .swf (Shock Wave Flash). I believe that you need to download it and install it in your N72. Please check the link below:
http://software.informer.com/getfree-flash-player-.swf-n72.swf/
Thank you and good luck!
Sep 13, 2010 | Nokia N72 Cellular Phone
How to install other swf format themes in lg bl20v new chocolate mobile other than the default themes. pls give full details
First chech whether it supports.then send a swf file into ur phone via bluetooth and check wat options do you have with it
Aug 04, 2010 | Cell Phones
No animated wallpaper in my n72 nokia
Hi, for swf file you need to install flash player and to play other MP4 files and other formats install corecodec player on the phone.
Rate it, if it helps.
Aug 03, 2009 | Nokia N72 Cellular Phone
O2 icon on main screen lg ku990i
its a hard coded part of the phone dependant on your network, however, google "viewty theme manager" and "EFS Mediabuilder" and download them. The next bit is a bit long winded, but bare in mind that once this has been done, any theme you pick with the theme manager (even the default one that the viewty comes with) will remove the O2 icon.
Run EFS Media Builder, and navigate to "LGAPP/Media/swf/theme". BACKUP "theme_bg2.swf". If you really don't want to **** things up, just backup the whole damn "theme" folder. You don't have to back it up but its strongly recommended you do,
I'm a phone flash modder, so i take the risks and can tell you ive had no problems with it whatsoever, but make sure you read the installation readme's you get with the theme manager and efs builder. If you google "installing viewty theme manager" there are also a few video tutorials on how to install the theme manager correctly. Once its been installed though you never have to worry about it again.
from the KU990.co.uk forums - a tutorial on how to install it:
To install it if you have a memory card:
1) Install "theme_bg2.swf" into "LGAPP/Media/swf/theme" using EFS Media Builder then restart the phone once done.
2) Navigate to Settings, Phone settings, Connectivity, USB Connection mode and pick Mass Storage from the list then connect the phone to pc
3) Switch USB connection mode to Mass Storage then browse to the Memory Card/Removable Storage.
4) Drag and drop the "Themes" folder from the rar file directly to the root of the memory card.
6) Navigate to Settings, Screen, Handset theme and pick Silver from the list.
Installing to Phone Memory
1) Edit the "ThemeList.txt" file to make all custom themes point towards the phone memory (//LGAPP/Media/swf/theme/Themes)
2) Navigate to "LGAPP/Media/swf/theme" with EFS Media Builder.
3) Drag and drop "theme_bg2.swf" file and the "Themes" folder into this loction then restart the phone.
4) Navigate to Settings, Screen, Handset theme and pick Silver from the list
You need to edit the ThemeList.txt if you install to the Phone as it currently set to the memory card location. Change the '0' to '1' for all the themes in the ThemeList.txt file.
All you have to do once it's been installed is pick your silver theme and click your "c" button twice on the home screen to bring up the theme manager.
I know its long winded to get rid of the o2 icon but unfortunately its the only way without removing hard coded files from the viewty and potentially breaking it =/
May 28, 2009 | LG KU990 Viewty
DElete Theme
Install same theme,Ur mobile Phone will be Asked to Replace Previous.Replaced Ur Previous.This Time That Theme will be Shown in Application Manager.Then Remove Ur Theme in Application Manager,then Delete that Theme From Ur Source File
May 04, 2009 | Nokia N85 Cellular Phone
Nokia 6233 slow start up and problem in SWF themes
You have to check your firmware version using this code *#0000# if the version is older than 05.60 .you have to update thru nokia pc suit.sure it works.
Jan 27, 2009 | Nokia 6233 Cellular Phone
Hi, I have a Nokia 6233 mobile. It is working fine but it takes at least 8 mins to startup when I switch on the phone. Another thing is it doesn't allow any SWF Theme to display properly.
make your phone formatted by nokia care centre your phone has definetly got some viruses which need some time in the begenig to execute
IPhone theme
go to this site http://gallery.mobile9.com/f/69109/
Sep 16, 2008 | Nokia N73 Cellular Phone
ANIMATED PICTURES
you need to convert it to gif and it must be smaller than 200kb, about swf files the ones stored on the phone cant be accessed or add more, cause its restricted (at least in usb mode cant see the animations folder) may be possible by some way to place or acess to them via usb cable but in data mode (the same as used on lg manager software) but still searching cause hate the backgrounds on the phone and nokia phones allow to see and use custom swf files.... :(
Dec 08, 2007 | LG Shine KE970 Cellular Phone
Nokia 6233 Cellular Phone Logo
107 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
