Question about HP PSC 1315 All-In-One InkJet Printer
My HP 1315 keeps printing the alignment page...many times, even t
In the past it only printed it once and then I did the procedure and that was it. Now, I have 5 copies of the alignment page and all that toner wasted! How can I turn it off?
    Problem Solver:
  • 7 Answers
Clean the feeder roller for possible debri and clean the encoder strip located at alongside with the carrier carttridge. It is usualy the done that guides your cartridge for alignment. Also try to inspeact and clean the encoder wheel located at the leftmost side of your printer. This is the timing wheel for paper feeder.
Posted on Dec 24, 2008
Hp 1315 printer alignment message comes on computer screen each time computer is turned on
you have to complete the alignment steps by scanning the page after it prints (put the printed page on glass and press scan button) . i hope that is helpful
Dec 01, 2012 | HP PSC 1315 All-In-One InkJet Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Hp psc all-in-one 1315. At start up and after a print job, the printer now prints out a test page. How can I stop this? Thanks Colin
Dear Sir,
Welcome back to Fixya
After changing ink cartridge,did you let the unit do an alignment? If not, you need to allow the unit to finish the alignment.If couldn't print another "alignment page" since the print queue was frozen in "pending" status ,so open the printer and remove and re-insert the ink cartridges.
Then place that "alignment page" on to the scanning bed and press the printer's scan button. The scanner startup again and 60 seconds later, then it start printing the documents remaining in the printer queue.
I think it deffinately solves your problem.If you have any problem regarding this issue leave a feedback we were happy to assist you.
Have a Nice Day!
Sep 30, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Prints test page every time printer is installed
Hi Jay,
This is mike, actually the problem is that that printer has not completed the aligning process, as a result the printer is printing the test page (Alignment page) every time when you turn it ON. So, I would suggest you to let the printer prints the alignment page and check whether the printer prints the page with all colors and it printed fine, once it is done, disconnect the USB cable behind the printer and then place the alignment page on the scanner glass by facing down the printed page downwards and press the scan button. This start the alignment process and the scanning process will be completed once the ON light is stop blinking. This will complete the alignment process.
Once done try to turn off and turn on the printer and check for the result. This should resolve the issue.
However, if the issue persist, then please revert back to me. Be sure that you use the HP genuine ink cartridges, not refilled nor re-manufacture.
Jun 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Test printing
If you've recently changed your cartridges, the printer will try to print a test/alignment page. Note the instructions on the test page indicate what to do to complete the testing/alignment procedure.
1) Let it print.
2) Place the test page upside down on the scan plate.
3) Hit "Scan" and let it finish.
When the machine completes the scanning procedure, you'll be able to switch the printer on and off or reboot your computer without it printing the test page. By Dubbya
Sep 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer
I think the alignment page is printing every time. Disconnect the USB cable from the printer and keep the alignment page face down on the scanner glass and press scan button on the all-in-one. We need to scan the alignment page once the alignment page is printed to complete the alignment process
May 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
140 people viewed this question
Ben Johnson
