Vokera 12-48 rs mynute boiler shuts down after heating for a while. Needs to be reset and lelit but after a few minutes shutsdown again. Complete gas valve, pressure differential switch and PCB have been replaced.
  • 85 Answers
SOURCE: Amana Gas furnace, Air Command
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Posted on Dec 02, 2008
rayname
  • 70 Answers
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
Posted on Jan 08, 2009
  • 234 Answers
SOURCE: vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Posted on Mar 15, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
  • 744 Answers
SOURCE: reversing valve not switching over to air on heat pump. compressor will come on for about 10 minutes, then shut off. Hot air comes out vent.
Look for any refrigerant leaks - no or low refrigerant can cause problems in both modes. The unit may be going off on low suction.
-OR-
The unit may be stuck in the heating mode.
Make sure the system is calling for the correct mode (cooling or heating) - some systems are auto, but if you can, select cooling since that is the requested mode. Check for power at the reversing valve inside the condensing unit. If power exists, then the reversing valve is stuck. It could also be the reversing valve solenoid coil, so make sure that isn't bad. There should be a strong magnetic field at the solenoid coil.
If you can hear the reversing valve clicking (moving), check the T-stat and make sure it will switch modes. Also check the reversing valve relay (those can be located in either the indoor unit or condensing unit).
Posted on May 25, 2009
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
My vokera mynute 25 ehe boiler was wroking fine until yesterday when my wife turned the selctor to 0, thinking she was turning it off. When i turned the selector back to 1 last night, the boiler wouldnt...
My name is Carla and I work for Vokèra in the marketing department, I am sorry to hear that you are having problems with your Vokèra boiler and I would like to help you get this problem sorted as soon as possible.
Please email me your contact telephone number and I will arrange for a member of our service team to contact you, alternatively you can contact them on the numbers below.
Email: marketing@vokera.co.uk UK: 0844 391 0999 (option 2) ROI: 056 7755055 (option 2)
Aug 02, 2011 | Heating & Cooling
I have a vokera mynute 16e boiler and the light is not coming on and there is no heat coming through the radiators.have messed with all the settings with no joy, please advice of any possible trouble...
If this is a newer boiler, if it has a control board with a 24volt output
check to make sure boiler has line voltage to it. No fuse Blown/Breaker
Tripped.
If that is not the problem and power is available it could be the thermostat. If there is a pump involved,make sure it can operate
Dec 27, 2009 | Heating & Cooling
Vokera mynute 14se lockout reset button on
Mar 14, 2009 | Water Heaters
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
