Question about Dacor ECD227 Epicure Electric Double Oven
Taking way too long to heat
One of the 2 ovens is now taking 3 times as long to heat to the correct temperature - was working fine before - instead of 10 minutes it now takes 30 minutes to reach 350. Any advice much appreciated.
  • 175 Answers
Usually when an oven is slow to heat, it is because of a bad element. You can look at the upper (broil) and lower(bake) and see if they appear to have any major burn marks on them, It may just look like something spilled on it untill you look closer or try to clean it off. if you do not find any obvious problems, turn the oven on and wait a fem minutes, then see if the bake element is glowing. Also look at the broil element, they should both be glowing at least a little orange. Compare how it works to the other oven that works properly. If only one of your elements is glowing, either you have a bad element (which is usually apparent on visual inspection) or a bad relay board that controls the element. The element is easy to change, onlt a couple screws and 2 wires (turn off the breaker first!!), the relay board is pricey, and a pain in the tookas. if you decide to guess, try the element first. Hope this is at least a little helpful.
Posted on Jul 01, 2007
Siemens oven not heating to high temperatures
possibly,but i would check both upper and lower elements are working first, lower element is hidden so test from the back with a multieter after removing oven fuse from the power box
Feb 03, 2018 | Siemens Ovens
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
We have a Westinghouse oven model WHG 645 KNG serial 90911136. It takes so long to heat up. I leave it on for 10 minutes then put on the fan. It takes ages before the gas seems to ignite at the back of the...
This is a problem with the ignitor. We have had this replaced 3 times in 10 years and the service technician says each time that he'll be back within the next 3 to change it. They actually haven't charged us for the parts the last 2 times because Westinghouse obviously know that it is a piece of $&@# .
Aug 31, 2009 | Ovens
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Jun 15, 2008 | Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Dacor ECD227 Epicure Electric Double Oven Logo
692 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
