Question about Hotpoint WMA74 Front Load Washer
Where can I get a manual for Hotpoint-Ariston WMA74
  • Hotpoint Master
  • 3,463 Answers
In your browser bar type in the following:
hotpoint user manuals, then click on manuals user guides and click on user manual , find your model and download to your computer or print it off.
Plz leave feedback for this solution.
Posted on Dec 15, 2008
2 Suggested Answers
prawinmv22
  • 106 Answers
SOURCE: My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Posted on Jun 12, 2009
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint wma74 washing machine fills with water then does nothing will not run drum or spin
hello it sound like the brushes on the motor could be the cause 2 plastic blocks sit either side of the motor these are made of carbon and wear down can cause the motor to stop working also the other causes could be interlock on the door and module control board hope it helps
regards
shaun
May 24, 2011 | Hotpoint WMA74 Front Load Washer
My hotpoint wma74 front load washer makes a very loud thumping noise on the spin cycle ive got a feeling it could be the dampers but would like some more info please, ive run a the cycle empty and there...
It does sound as if at least one of your dampers are gone. Unplud the appliance from the wall, take the back cover off and see if there is any movement when you try shift the drum. If there is a lot of play on one side, that damper is likely gone.
Dec 12, 2010 | Hotpoint WMA74 Front Load Washer
Purchased refurbished machine to replace wornout wma35 can you please supply user manual thank you
Go to the following site.
WWW.HOTPOINT.SERVICE..CO.UK
On the menu on hte left, click on USER MANUALS, and enter the model number in the search box, download the instructions.
Nov 21, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint wma74 wont spin
It could be the motor's carbon brushes have worn out. Replace with the same type. Need to get at the motor, you simply unscrew and slide out. If they are hard to reach then you will have to take the drive belt off and remove the motor and then take them out. These brushes provided the electricity to the motor in order for it to spin.
Aug 09, 2010 | Hotpoint WMA74 Front Load Washer
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
Mar 04, 2010 | Hotpoint WMA74 Front Load Washer
Very little water on wash cycle
water level is determined by the pressure system, and no adjustment can be made.Ensure your programe is not selected to half load.
Feb 18, 2010 | Hotpoint WMA74 Front Load Washer
How to change bearings on hotpoint wma74
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Feb 08, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
467 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
