Question about Sharp AR-207 Copier
Error Code E 7
We replaced the toner cartrudge on my Sharp AR 207 copier. Now the error message "E 7" is flashing.....Help!!
Thanks
    President:
  • Sharp Master
  • 990 Answers
Press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Posted on Dec 15, 2008
  • Everett Lin Dec 21, 2008
    Hello Sir; Last time I post out reset procedure for your copier I don't know does it work ,please let me know, if you need more help just email me I'm happy to help you, good luck !
    Meanwhile, if you satisfy my service please give me a good rating,
    THANK YOU !!!
TENGO UN ERROR F2-04 EN SHARP AR257 YA CAMBIE EL CHIP Y NADA QUE ME FALTA POR HACER?
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
Feb 19, 2011 | Sharp AR-207 Copier
My Sharp AR-207 gets a U2 error code. Nothing happens now. What is wrong, and how do I correct?
When your copier toner cartridge sensor is blocked.then problem arise ut or bios battery is not configure program.
reset : # - interrupt - C -interrupt press 16 press start key.
Jan 28, 2010 | Sharp AR-207 Copier
SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Jun 30, 2009 | Sharp AR-207 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
I have a sharp ar 207 copier. It is giving an error code of U 2. When you press "copy" it gives a code of 40. I cannot locate the service manual. Can someone help?
you have a problem with the chip on the toner cartridge
you have to reset this via simulation 16!
if it's a refilled one have the recycler do it and replace the chip
if it's an oem ask sharp
Jan 25, 2009 | Sharp AR-207 Copier
Error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
U2-40 error etc.
U2 is a memory error. It's either the RAM or the ERPROM. A techincian has to look at it and determine which part it is and replace it. The copier won't run until it is fixed. It could be a loose memory board as well.
Sep 02, 2008 | Sharp AR-207 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp error code U2
you can get rid of this u2 by pressing buttons as follows: # , interrupt, C, interrupt sequentially. then enter the no. 16 and press the start button. good luck
May 15, 2008 | Sharp AR-207 Copier
Sharp AR-207 Copier Logo
211 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
