Solution #1
posted on Aug 08, 2005
Ross - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
All Chips generate heat when running, so the thing to do is decide if you're just feeling normal heat. If you can't leave your finger on the problem chip for several seconds - its bad.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 07, 2008
you might want to put cooling fans on your amp to help cool it down or move it to a more airy spot in your vehicle all amps need air circulation if no air the amp will fry
Solution #4
posted on Apr 21, 2008
little solution for them amplifiers warming up the red neck way and the city way i will speak of especially during summer
Red Neck way
get 2 funnels any will do put one in front of vehicle mounted for air flow get a hose make sure to cut to length
mount this hose under vehicle mounted to chassis make sure end of funnels are hose clamped off drill hole threw floor stick the hose threw connect other funnel mount close to amplifier you just made a vent for amp with air
City way
Buy some cooling fans proper to the amp and mount on amp accordingly to releave warm hot air
anything else wouldnt be productive
Red Neck way
City way
Solution #5
posted on Mar 18, 2008
High power audio will always generate heat, Class D amps should generate less but will still genereate some. The chips are should at least be designed to work up to 85degC = 185degF. Audio units should also have heat protection built in, almost all decent audio electronics should shut themselves down when they get too hot. If this happens to you often, consider mounting it in a different way to get more cooling air to the unit.
Solution #6
posted on Feb 25, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
tengo problemas con me radio boss 630u que me da un error en los lectores usb y sd card estos esrrores son 12 13 14 que puero hacer y cuales son estos errores
Solution #8
posted on Jan 22, 2008
Is this a Nakamichi deck? Its typical if it is . Shouldnt have to wurrli.. Your cd's might be hot too when ejected [if it's a cd model] bob c camache ,ia. p.s. Nakamichi decks will make you want to change your speakers after you install. They are that good. DO NOT BUY ANY OTHER CAR AUDIO DECKS OTHER THAN NAKAMICHI. YOU WONT REGRET IT UNLESS YOU HAVE HEARD THE DIFFERENCE NAKAIMICHI DECKS MAKE IN YOUR SOUND. THEY START AT ABOUT [CD DECKS] $200.00
Suggest a new solution for this problem
Post a New problem for Tomtom GO 700 GPS NAVIGATION BRAND
Email this problem
Email this problem
This Problem Also Relates To:
Audiovox P99 CD Player
Jensen CD-4010 K CD Player
Jensen CD-615X CD Player
Jensen CD400M CD Player
Jensen CDH-1000 CD Player
Kenwood KDC-MP4028 CD Player
Kenwood KDC-MP335 CD Player
Can you Help with these In Dash Receivers problems?
Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95...
Get the ohm right
Get the ohm right
How do i wire 6 4ohm speaker... Answer This...
tomtom navigator 3 for pda
Please can you help me id like... Answer This...
I hooked up my TomTom
I hooked up my TomTom Go 720 to... Answer This...
Audio distribution
Audio distribution
I have 4 sets of 16g pre wired... Answer This...
my tom tom go 700
my tom tom go 700
my tom tom go 700 will not... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
