Rscharff,
I am having the same freezing melting onto the floor problem you posted about. I was just wondering if you have solved the issue and if so how?
Thanks,
Scott
Yes, I fixed my problem of the plugged drain that caused the ice to melt onto the floor. Apparently, frostfree frigs have a drain that leads to a pan under the frig by way of plastic tubing from inside the freezer compartment. The drain tube end for my frig only had about 1/8" clearance above the pan bottom. The pan was dirty with an ENORMOUS amount of dust that had collected. So, I had to move the frig out from the wall, remove the back cover at the bottom of the back of the frig. This exposed the white tubing and the gross pan of dust and water paste. I cleaned the pan, disconnected the tubing from the clip holding it in the pan and trimmed about 1/4" off the end to create a bigger clearance into the drain pan.
Make sure the frig is unplugged before you do the job so the evaporator fan doesn't hurt you.
Now, I will have to clean from behind the frig at least once a year.
Hope this helps. Good luck.
Bob
