Toshiba Sony CDXM850MP CD Player
Problem for Toshiba Sony CDXM850MP CD Player
Sony CDX-M850MP Remote wont work when front panel closed.
By barnaclesbil on Dec 15, 2008
The front panel on my player was not working properly although I could open and close it with the remote and adjust volume etc. The display itself was the only thing that would not work. I purchased another set which was faulty (no audio on 3 speakers) this unit had had the ribbon replaced on it by the previous owner. I set about changing the complete front, a very easy job, and everything went well. When I powered it up all the lights worked and the display worked well. The only problem I have is the remote control will not work with the front panel closed but works perfectly with it open. Would be good to get it working right again, any help would be appreciated. Thanks Bill.
Best Solution
posted on Apr 09, 2009
Very Helpful)
rmilbrett
Rank: Apprentice
Rating: 100%, 1 votes
The problem is the flexible wire strip that cracked. I just had the same problem. A guy has them on auction on e bay. Type in model number and flexible replacment for search.
Fix by.
1. Unscrewing 2 the two screws that connect faceplate to motorized flip bracked. One on each side.
2. Unscrew the screws that are connected to the back plate. Plate directly behind faceplate with Blue LED.
3.Unclip backplate by sliding Deck out 1 inch. Two clips on each side.
4.Unclip the waferboard/circuit board from the back plate.
5.Remove Flexible wire band that connects the faceplate to backplate.
6.Attach new flexible wire band to deck then to face.
7. Reclip everything, Rescrew everything.
Whalah it is fixed.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Toshiba Sony CDXM850MP CD
Questions and Unsolved Problems for Toshiba Sony CDXM850MP CD
Do you recommend Toshiba Sony CDXM850MP CD Player?
Answer
Answer
i have a cd2 fine arts cd player the problem i have is when a disc is loaded into the draw it will... (More)
Answer
CD player turns on but won't do anything else, and tray won't open.
Answer
output level remote control does not work any more. all other functions of the remote control are... (More)
Answer
I have Toshiba Satellite A205-S4607 with Vista ,less than 2 years old . I am able to play only... (More)
Answer
You say you found the solution to your problem. Can you let me know as I have the same problem.... (More)
Describe your CD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD Player Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
