Question about Zenith ZHD-311 300W Complete Home Theater Sound System, Progressive Scan System
I was messing with the settings on my Dvd player, and now i have no video
I dont remeber what setting but it made me confirm what I was doing, and then I lost all of my video output and I cant go back to change the setting since I cant see what Im doing, does anyone have any idea what setting it was and how I can change it back. If you can help I THANK YOU IN ADVANCE. Selected prog. scan and lost video. the setup does not show either zenith zhd311
    Master:
  • 479 Answers
  • 599 Answers
Look in manual for total reset procedure and start fresh
Posted on Dec 15, 2008
DVD model #mwd7006 sound but no picture
  • To reset the DVD player unplug the DVD player for 10 seconds.
  • Confirm that the TV has been set to the corresponding video connection of the DVD player.
  • DVD player has three video outputs.Video, S-video and RGB-component.
  • If current connection to TV is not working and the TV has an alternative video consistent with the DVD player try the second.
  • Try DVD player on another TV
Nov 24, 2015 | Televison & Video
Menu screen wont come on
Check video connections first. If previously working, confirm screen is in proper setting to allow play. Get small TV with RCA Video connectors and connect your DVD to small TV to confirm you have video coming out of player. if no video then it's your player. Replace player! If you have video then replace screen
Jun 14, 2014 | Valor ITS-701W Car DVD Player
When i first got my xbox i put family settings on and i dont have live. i cant remeber the password or the reset password. what should i do?
when i first got my xbox i put family settings on and i dont have live. i cant remeber the password or the reset password. what should i do?
Aug 05, 2010 | Microsoft Xbox 360 Console
I tried to install my emerson dvd player and the play stop fr button light all stay on and picture and sound dont go on I connected another dvd player and the video does show on screen
It is now confirmed that your emerson is faulty. Please remove the connection open the set if there is no breach of warrranty- if new- and look inside. try and tighten all the connector points, the joints, the flat cords. check the leadds to the front panel and check for any breaks. Assuming this was working earlier and has failed now, then you will need to check on the display/ processor for failure. If aftera ll this check the light are staying on then you have a possible failure of the micro processor. confirm with a signal check, frequency oscillation and if not present replace. Helpful? Good day
Jul 13, 2010 | Emerson DV-X1411TN Car DVD Player
Dvd player wont play video. it says "cant watch video while driving" but car is in park or in ACC and still says the same thing. how do i fix this?
Please recheck to confirm if the line fromthe parking switch is deactivating the player. open the connections and check for voltage, check if the car handbrake light are coming on while the handbrakes are on. if so is this connection comiing to the set. I am sure if you can cross over the connection the set will come back active. I dont think there could be any more fault unless the trigger to the processor has failed which incidentely you will have to remove and check within or bypass.I would still like to stick with the brake switch. check this out. Good day
Jul 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
DVD Player will not play in color?
I dont think so  the DVD palyer is playing the videos that means the Player is connected properly
i would suggest you to check the color settings either of the DVD player (you might find how to do this in the manual,  would be easy) else check  wheather the color setting on your tv  are not set to SCEAM on the video mode.
hope this helps otherwose  please do post back and pls dont forget to rate the solution
Nov 23, 2008 | Memorex Televison & Video
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
Dont have any image
Remove any disc which may be in the player. Make sure that the player is "on" (green light is "on" at front of player). Hold the "stop" button for at least 5 seconds (square symbol on the player is the "stop" button). This will reset the player to the most basic of video settings. The yellow "video" jack at the back is the basic output for video. The red and white jacks are the basic sound outputs (right and left if in stereo). Good luck.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
49 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
