Question about iLO DVD Recorder DVDR05
Random codes keep poping up when it does work!
Hi Ok my dvd recorder was working fine playin my Cd then i turned it off and it is connectd to my tivo and tv! So when i wanted to watch tv i tried to turn it on and it would not turn on! It started to make a non-stop high piched beep sound! So i unplugged it trying to reset the whole system! But when i plugged it back in it turned on and popped ip a code 0117 P then it went away! So i did it again and the same thing happen only the code was 0211 P. The n I tried it one more time and the time popped up and staid awile but then went away. I can't watch my tv cause it is all hooked up as one system! What should i do? Antony
  • 32 Answers
Like a vcr, t.v. signal-IN connected through the 'antenna'input, the t.v. signal should pass through the dvd recorder and u should see it even if dvd machine is off. How is dvd, Tivo, t.v. connected? Signal connected to [video input1],[s-video input]BEFORE OR AFTER tivo ? I assume that the t.v. is the last in line??!! I am sorry, my book does not have code explaned
Posted on Sep 26, 2007
I was trying to record documents on a cd when I got the following message: Code erreur 380394-26-2A030C00
HI ,
1° It could come from the cd . Try with other models .
2° Go to my computer and right click on dvd device and click on properties then click on recording see if your decice is checked for burning.
3° Try restoring your computer to an earlier date , when your drive used to work fine .
4° Connect an external device and see what happens . If it works , your burner needs to be replaced .
Best regards .
Jan 24, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
FUNAI B2735 DVD/VCR COMBO
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Funai PY90VG DVD Player/VCR
C13:00 error code on rdr HX-725 when i put in a cd. DVD's are playing ok, so is the HDD.
Try to turn off the machine (deplug it) for at least some minutes - and turn it on again. That worked for me! ;-)
Dec 21, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
Dvds not playin
It may be a problem with the laser or the lens. If the DVDs work on another player, try first to have the lens cleaned. You may use a lens cleaner with cleaning solution for this one. If that does not work, you have to inspect the disc drive closely and check for physical damages on the circuit like burnt parts or leaking capacitors. Inspect the lens as well.
Oct 30, 2009 | LG DR275 Recorder
MACBOOK PRO SuperDrive Reads somes Recorded DVDs fine but some appear as empty while in other mas are fine
some pioneer dvd models have firmware upgrades to solve problems with some DVD brands - check your model and visit the pioneer components website - I have a DVD reader which worked better after the firmware upgrade - try this site http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVRZ44G&upd_id=1692&os_id=16
May 28, 2009 | Apple Genuine Pioneer "SuperDrive"...
MY PIONEER DVD RECORDER WILL NOT RECORD BUT PLAYS
hi have you tried to format the discs this sometimes work check your manual and it should tell you how to format
Dec 15, 2008 | Televison & Video
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD unit doesn't read CDs but works fine with DVDs
Sir: Did you try another CD or just 1 CD could not read by your DVD RW? Would you please make the DVD poped out and re-set it again. It seems the problem of communication becasue the code rate of DVD and CD is different. Its not related with the lens.
Jul 20, 2007 | Sony VAIO PCG-K35 Notebook
iLO DVD Recorder DVDR05 Logo
54 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
