Question about Edimax BR-6104K Router (br6104k)
Dhcp disabled How can I access the site http://192.168.2.1 if I've disabled the dhcp. I have since than no connection to the router edimaX BR-6104K. Thanks!
  • 54 Answers
I'm not too sure how you are trying to access the router (wired or wireless) or what operating system you are using, but you will need to manually set your IP address (through Network Properties) on the computer to 192.168.2.10 (for example) with subnet mask of 255.255.255.0.
If you also want internet access you will need to set the Gateway and DNS to 192.168.2.1.
Once that is set you will be able to try bring the page http://192.168.2.1 again and configure the router from there.
Once you configure the router (i assume you want to turn on DHCP again) you can set your computer back to DHCP assigned IP and DNS.
Posted on Dec 15, 2008
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
How to configure edimax router BR-6104K
How to configure edimax router BR-6104K Problem with the Edimax BR-6104K Router
Jan 19, 2011 | Edimax BR-6104K Router (br6104k)
Hello everybody.. i'm just looking for an
Be specific!!!! upgrade in drivers or device it self?
This link has a firmware update--- http://www.opendrivers.com/driver/236219/edimax-br-6104k-broadband-router-firmware-v3.25-free-download.html
Jul 03, 2009 | Edimax BR-6104K Router (br6104k)
Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
http://www.edimax.com/images/Image/QIG/Wireless/BR-6204Wg/BR-XXXX_QIG.zip
Nov 03, 2008 | Edimax BR-6104K Router (br6104k)
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
How to config my edimax 6104k router???
1You can run the setup CD or manually configure it using the user interface of the router.
2.Since that is a router all devices that will be wired to it should automatically get an IP address from it.
3.Since they will be connected to the router you just need to enable file sharing on each computer.
May 07, 2008 | Edimax BR-6104K Router (br6104k)
Edimax br-6104k
well, it just works now! :-) i can access the config page. idon't have a logical explanation.:-P
Apr 21, 2008 | Edimax BR-6104K Router (br6104k)
Edimax br-6104k
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
marlon
Jan 16, 2008 | Edimax BR-6104K Router (br6104k)
How connect the edimax BR-6104K router using the PPPoE connection
Let's see if this things work..
First open the internet explorer browser. On the Address bar, type 192.168.2.1.
The site will ask you for username and password. The default username is admin and password is 1234.
The edimax page will appear, click the quick setup wizard.
just follow the instructions. The site will ask of your broadband type; click the PPPoE x DSL and fill up the required information.
Type your Username, Password, and Service Name and other info.
That's It!
Hope this one helps you...
Dec 28, 2007 | Edimax BR-6104K Router (br6104k)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router (br6104k) Logo
261 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
