Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Dishwasher fan fills with water
The drier fan on my Miele g646sc dishwasher fills with water during the wash cyle and then when door opened all the water falls out the front. drying poor as a consequence. obviously some trap door in the fan compartment not closing properly. diy fix possible?
  • mishymashy Feb 15, 2009
    Just tried to solve this by unscrewing the front door panel of our Miele G692SC  freestanding dishwasher, and cleaning the small hose.As advised by a few people;s replies.  There was a little dirt in there.  Bit of a mission to get the door back on- but it haas just completed a cycle, and seems cured!   Fan sounded normal, and no water on the floor. Might be early days, but we will see!   Thanks for all advice.
  • Anonymous Mar 13, 2014
    i dont think water is going in the dishwasher when i open the door its dry
  • 3 Answers
Well, I just took my hose out (pulled both ends off the connectors) and it was indeed full of junky cruddy muck, so blew it out over a waste bin until it ran clear through. Now I've put the hose back on and will see what happens next wash!
Posted on Oct 22, 2008
I had exactly the same problem. Just took the front panel off (bottom two screws on each side of the door), removed the hose and blew all the crud out. Problem fixed.
Posted on Jan 20, 2008
I am experiencing the same problem with my G851SCI dishwasher and came here to look for solutions. Did you finally remedy the problem?
Posted on Jul 26, 2007
  • marilyn trudell Jul 26, 2007
    just called the miele 800 number. Seems the hose from the fan is plugged. He said to unscrew the edges of the door to split it open, remove the hose at the bottom of the fan and clean it out. If I have problems then call for a service call.
    Novelist:
  • 269 Answers
You have the Miele problem, and have found the usual solution.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Posted on Jan 26, 2011
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
You have the Miele problem.
Jan 16, 2011 | Miele Dishwashers
Our Miele dishwasher has started to make a noise when the drying cycle starts, 25 mins from the end of the programme. Sounds like a the fan bearing or, because it's pretty new, maybe it's obstructed or...
And do you get a pool of water on the floor when you open the door and the fan drains out? If so, then you have the Miele problem.
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked before.
Nov 27, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
MieleG870sc I can hear the motor, but water does not seem to be coming in and after cycle ended, soap tablet was unused?
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Mar 01, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 21, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
May 19, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Mold in the rinse aid compartment.
You should check your pump located in the back of the machine to make sure that it is pumping water out. Also see why the fan is making noise and replace the fan. Also check your hot water supply. Mold wont grow if the water is the temperature it is supposed to be and seems like youa re just washing with warm water or even cold
Feb 16, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher won't fill - inlet/outlet light comkes on
check no water in the base either by taking front bottom panel off or tilting back. if water runs out, means you have a leak. could also be inlet valve open circuit
Apr 10, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
1,398 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
