Question about Refrigerators
Freezer whistling noise
Freezer is always putting off a whistling noise
  • jcgoza11 Jan 16, 2009
    thank you
  • miamireal Mar 24, 2009
    my jenn-air 48" side by side refrigerator is "whistling" too.
    i dont know if it always has or just started but certainly for the last two weeks it has been emitting a high piched whistle or buzz "eeeeeeeeeeeeeeeeeeeeeeeeeeeee"
I have a similar problem. I have a side by side freezer that hums/whistles incessantly. I was reading another thread which suggested that this only happened when the ice tray (automatic on the door ice bin) is full does this happen. Wouldn't you know it, but mine was full. Took it out, knocked out about 1/2 the tray into the sink, put it back together...and BAM!! Whistling has stopped.
Posted on Mar 09, 2009
  • Refrigerators Master
  • 5,568 Answers
I assume the noise is only there when the compressor is running.
This can be caused by the expanding coolant/gas that removes the heat from inside the cabinet passing through a restriction in the coolant tubing.
It may be annoying but unless the unit isn't doing what it should, I don't think this is harmful.
Posted on Dec 15, 2008
Whistling noise freezer close
Hello sangpark003 - Often when the unit is making a whistling noise, it is because it is pulling air from the outside. Sometimes a poor door gasket could be causing the whistling. You may check if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. However, if issue persists, I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts or to confirm if it is a normal operation noise.
Mar 28, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Tip
Side by side refrigerator whistling sound coming from freezer fan area
We had a lot of inquiries with what we call whistling appear to be from different problems which here below:
First case, whistling sound is what we call "Ghosting". To get rid of this sound one needs to put more gas into the system, but more gas will create the suction pipe to frost up and reducing the gas level will create less cooling. The best solution were to full regenerating Freon gas mean remove it filter it out and charge it back. However this will cost more $100 and basically you can leave it and live with it. No harm is created only the sound appears while running.
Second case were with a loud whistling, like a dying bird stuck in your freezer, you likely have a faulty freezer fan motor and you need to be replaced
Third case were with a lower pitched, sort of gentle whistling sound then you have an issue with the door damper, which allows the air flow from the freezer into the refrigerator. And assuming you don't have any cooling problems, it may simply be a normal occurrence, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Fourth case was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. We found out that the motherboard was probably defective.
Rather than go thru GE, you can found a new one online for 66 bucks. You can replaced it in about ten minutes and it's all fixed.
Fifth the evaporator fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evaporator fan motor. If this voltage drops out or fluctuates, it's more than likely the board need to be replaced
on Sep 14, 2010 | Refrigerators
Hotpoint hss25gfp has a whistle
Fifth the evaporator fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evaporator fan motor. If this voltage drops out or fluctuates, it's more than likely the board need to be replaced.
Apr 20, 2012 | Hotpoint Refrigerators
Whistling sound from inside freezer compartment
is this a loud whistling, like a dying bird stuck in your freezer, or is this a lower pitched, sort of gentle whistling sound. If its the former, you likely have a faulty freezer fan motor. replace
if its the latter, sounds like you may have a issue with the door damper, which allows the air flow from the freezer into the refrigerator. However, assuming you dont have any cooling problems, you didnt mention if you do, it may simply be a normal occurance, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side - PSS26lsrc - Unit whistles - like wind noise. Also does not produce as much ice as it used to. Need to pres 'quick ice' to get it to make ice.
I know of two things which can cause the noise. Since it hasn't always made the noise I would guess the motherboard is making it. Try to pinpoint the noise. Your motherboard is on the back. Part 801 on this diagram. If this is where the noise is coming from and you can put up with the noise, you can wait till you have more trouble with it. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PSS26LSRCSS&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-R-SERIES&diagramPageId=00009&componentDescription=SEALED%20SYSTEM%20&%20MOTHER%20BOARD&documentId=G0503214&backToLink=Return%20to%20Sub%20Components%20list
Another cause I've seen is because of the unique shape of the condenser coil. With the air pulled through it it can make a noise. It may help to clean the coil which may also help the ice situtation. It's part 730 on the diagram.
Sep 08, 2009 | Freezers
Whistling speakers
if your running a amp your power wire and rca"s are to close then you my have to seperate them.no amp double check wiring always try to keep power wires away from other wires signal jumps.they sell noise reduction boxes(cheap).i"ve had 50\50 results worth a try
May 04, 2009 | Car Audio & Video
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
1,047 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
