Question about SanDisk Sansa m250 MP3 Player
Create playlist I want to create a playlist on my Sansa m250 and I am using Windows Media Player 11. Would you explain how playlists can be created?
    Sergeant:
    Novelist:
  • 327 Answers
They can be created on the mp3 player itself. Set the player in Advanced mode (menu>settings>Advanced to ON). Once a song is playing, if you press and hold the center select button, it will say, 'Add to favorites' and have a check and a X. Select the check (default) and press the center button again. To remove it from the list, press and hold again; it will ask if you want to delete; again, select the check. This will remove it from the list only; however, the file physically remains on the mp3 player. To clear the entire list, go to menu>settings>playback>clear favorites.Note: Each time the mp3 player is attached to the computer, even if nothing is added or removed, the favorites list is erased.Playlists stay on the device even if connected to a computer or if the device content is changed.The Sansa m200 series has 2 different USB modes:--MTP (Media Transfer Protocol), a protocol released my Microsoft to support DRM (Digital Rights Managment), used for subscription Music services.--MSC (Mass Storage Class), when using as a regular removable drive.To switch modes, from your player. go to Menu > settings > USB >The two options are MSC and AUTO DETECT (MTP)You can create playlists on your player through Rhapsody, Napster, Yahoo, MusicMatch, Jukebox and Windows Media Player 10 if you set the player to MTP mode.If you are using Rhapsody,--Save a playlist (under the play tab in the mixer, select save).--Take the playlist and drag it to the sansa player in the top left hand corner on the interface where the device shows.--Do not drag it to the transfer tab in the mixer as this will transfer the files only and not the playlist itself.If you are using Napster,--Create or Save a playlist (bottom right of napster interface).--Under 'My Playlists' on the left of the Napster interface, right click the desired playlist. Select the 'transfer playlist to portable device.'If you are using Yahoo,--Follow the procedures in Yahoo to create a list and transfer it to device.If you are using MusicMatch,--Create a playlist either by dragging files to the playlist manager or by right clicking the file in your library. Select send to>portable device.--Open the playlist manager (view>playlist manager).--Right click the playlist and select send to >portable device.If you are using Windows Media Player 10,--Create a playlist by right clicking a song in the libary, add to>additional playlists>new or by saving a now playing list.--Select the Sync tab and click 'Sync settings.'--Place a check next to the playlists they want to transfer to device.--The Windows Media Player should then sync those lists once you hit 'OK.'Playlists can also be added in M3U format when the player is in MSC mode. This not officially supported. The following is a suggested workaround:--Make sure the player is in the MSC mode--Create/save an M3U playlist file from any application (winamp, windows media player, etc.).--Find file through My Computer, right click the playlist and Open With >Choose Program >Notepad.--The first line of the file should be #EXTM3U. After that, you will see 2 lines of text for each song in the playlist. Leave the first line alone for each song.--For the second line, you need to delete everything except for the filename (which is everything before and including the last).--Repeat that step for every song listed. After that, save the file by going to >File >Save.--Copy-and-paste the m3u file to the Removable Disk.--Copy all the songs to the Removable Disk by making a folder on the Removable Disk called 'Music' and copy songs into there.Regardless of method, the playlist will now show on the mp3 player under >menu >play music >playlist.If you wish to delete created playlists.If the playlist was added via the M3U method, deletion can be achieved by deleting the M3U file while connected to the computer in MSC mode.
For any playlist transfer via any MTP mode, you can either delete the playlist folder under Media folder on the Sansa M series on the PC (this will delete all MTP based playlists. They are not selectable, and on the PC, the folder will show as empty even when the playlists are present.)You can view and delete the individual playlists transferred via MTP in MusicMatch regardless of which MTP method was used to create and transfer the list. Bring up the portable device manager (>view>portable device manager), right click the playlist to delete, and select 'Remove.'Regardless of the method used, only the playlist itself will be removed. Any music referenced will remain on the mp3 player and can be manually deleted.
Posted on Dec 16, 2008
    President:
  • 2,110 Answers
Solution 1In the Sansa drive in Windows Explorer select the songs that you want in the playlist. Right click and create playlist. You can do minimal playlist editing through the playlist file properties. Drag files to the references tab to add files.
There is a free playlist creator which creates playlists for each folder on the sansa player with one click. it is written in .NET and does not alter the music files (http://www.infosys.tuwien.ac.at/staff/cp/playlist_creator.zip).
There is also one written in Python that should work on both linux and Windows (http://people.ifm.liu.se/yohell/make_playlists.py).
[edit] Solution 2Try Musicmatch Jukebox or MediaMonkey.Both of those should be able to create a music library using only filesfrom the device. Then sort them by artist and album, and delete themfrom the library, deleting the files as well. Transfer new files to thedevice as files (MSC USB mode on the player), not by syncing. You can create a new music library on the fly if you've made extensive changes. It doesn't take much time. Playlistsshould not contain drive letters or folder names, so edit them inNotepad, unless you have an app that makes them on the fly(suggestions?).
You can keep your main database in MediaMonkey, and open the Sansadevice (see the plus and click on it). You'll be able to delete filesfrom there. But if you double click on a song on the Sansa device, thewrong song will play. Dunno why, but that's what happens on my computer. But deleting files works.
[edit] Solution 3Rename all your tracks so artist (look for batch renaming feature inyour software. Add example of freeware editor?), album and song name isin the file name. That won't be visible in the player, but can aid administration if you use the player in MSC mode.
[edit] Solution 4A how-to for using Windows Media Player and syncing to make playlists can be found here.
added by thatsRich 04-08-06 - I was having trouble sorting onmy Sansa m250 using drag and drop with basic file management for mp3s.After seeing this article, I tried Windows Media Player(version 10) and found that perfect for the job. Since you can dragmis-sorted files in the left pane, they "sync" in proper order.
    Sergeant:
    Champion:
  • 304 Answers
MSC mode. Open the mp3 player using explorer, open the audible folderin there. Drag in whatever folders full of music you want, todifferentiate the different playlists.
Open your music player ofchoice. open a new playlist in it. click open one of the folders youdragged into "audible" to designate playlists, and highlight all themp3s. drag them into the "playlist" for the computer music player. SAVEthat playlist in the default format INTO the same folder you draggedthe mp3's from, on the mp3 player itself.
How to Add a Playlist in WMP10
How to Add a Playlist in WMP11
video
  • SanDisk Master
  • 13,433 Answers
How do i create different playlists in my sandisk sansa clip. It will play all it will play albums. I have tried to drag a playlist from the lap top windows media player but it says it needs converting to...
1) Open the Sansa in 'My Computer'
2) Double click on the 'Playlist' folder
3) Drag the music you want from the computer into the 'Playlist2_bing.gif' folder
4) Highlight all the files (or the files you want)
5) Right click
6) On the menu that pops up click "Create Playlist" - on my computer it's the very first option, in bold
7) Playlist will be created in the 'Playlist' folder
8) Name it whatever you want and enjoy!!
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
How do you create a playlist?
Solution 1 In the Sansa drive in Windows Explorer select the songs that you want in the playlist. Right click and create playlist. You can do minimal playlist editing through the playlist file properties. Drag files to the references tab to add files.
Solution 2 Try Musicmatch Jukebox or MediaMonkey. Both of those should be able to create a music library using only files from the device. Then sort them by artist and album, and delete them from the library, deleting the files as well. Transfer new files to the device as files (MSC USB mode on the player), not by syncing. You can create a new music library on the fly if you've made extensive changes. It doesn't take much time. Playlists should not contain drive letters or folder names, so edit them in Notepad, unless you have an app that makes them on the fly (suggestions?).
You can keep your main database in MediaMonkey, and open the Sansa device (see the plus and click on it). You'll be able to delete files from there. But if you double click on a song on the Sansa device, the wrong song will play. Dunno why, but that's what happens on my computer. But deleting files works.
Solution 3 Rename all your tracks so artist (look for batch renaming feature in your software. Add example of freeware editor?), album and song name is in the file name. That won't be visible in the player, but can aid administration if you use the player in MSC mode.
Solution 4 A how-to for using Windows Media Player and syncing to make playlists can be found here.
added by thatsRich 04-08-06 - I was having trouble sorting on my Sansa m250 using drag and drop with basic file management for mp3s. After seeing this article, I tried Windows Media Player (version 10) and found that perfect for the job. Since you can drag mis-sorted files in the left pane, they "sync" in proper order.
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
Nov 03, 2007 | SanDisk Sansa m250 MP3 Player
Sansa e250
You need to create a playlist first
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
How to create multiple playslists for M250
Alright, well if you are adding songs to your MP3 player by using Windows Media Player, you can create playlists there, sort the songs into what playlists you want them in, right click the playlist, and click "add to sync list".
If you are manually copying and pasting the music into the mp3 player (that's how I do it) it's a little less obvious... For me there are three main folders: Music, Playlists, and RECORD. So we want to go to the playlists folder. In there, assuming you have at least one playlist already, you can copy and paste it, naming it something else and changing its properties as you see fit (right click -> properties). To add songs to the playlist, you go to it's properties, and under the references tab, drag the music files from wherever you have them stored and drop them in the references tab. This won't move your music, it'll just add them to the playlist. and.... guess that's about it. Hopefully that helped.
Feb 24, 2007 | SanDisk Sansa m250 MP3 Player
Can't create or play 'playlists'
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
Jan 20, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
