Question about Frigidaire FWS445RF
Newer frigidaire top load washer belt replacement
How hard is it to replace the belt on this model fws445fr? any tricks I need to know?
    President:
  • Frigidaire Master
  • 2,651 Answers
Simple to replace, it simply wraps around the motor , over to the transission pulley, and the pension pulley applies "tension", will only go on one way, 2 screws across the bottom of the front panel will gain you access to the area
Posted on Dec 15, 2008
I have a frigidaire washer, when drum spins it
It is probably the belt.. Replace the belt and that should take care of it..
Have a nice day..
Sep 08, 2009 | Frigidaire CWS3600AS Top Load Washer
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
I need to replace belt on kenmore heavy duty washer, do I have to remove drive unit?
MOST NEWER KENMORE WASHERS ARE DIRECT DRIVE AND HAVE NO BELT,THEY HAVE A COUPLER BEWEEN THE MOTOR AND TRANS,LET ME KNOW IF THIS IS THE CASE WITH YOURS-MIKE
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Changing belts
Order a Belt:
Appliance & Electronic Parts
NASTASI’S DISCOUNT
APPLIANCE & CONSUMER ELECTRONIC PARTS
TOLL FREE 888-338-3790 (PARTS ONLY)
8:00AM to 12:00AM - 7 DAYS A WEEK
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Replace belt
Before offering assistance I need to know if the old belt is still on the machine and in tact. The procedure is a little different if the belt has broken.
Dec 08, 2007 | Frigidaire FEX831CS Top Load Stacked...
How do i replace the belt
simple enough the replacement belt hooks around the tranny pulley and the motor pulley, theres tension pulley spring mounted to the motor assy (spring loaded) simply push it in and wrap the belt around the outside of it so when you release it it adds tension to belt, your done!
Sep 28, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
