Question about GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop
Gas not igniting
Some of the burners on my GE gas cooktop are not lighting. The igniters appear to firing okay, but the gas is not lighting quickly, or at all in some cases. I get paranoid of a house full of gas, and shut it off after a second or two. I have now resorted to using a lighter to use those burners, but that's just not right. One time while trying to troubleshoot this problem, I swapped an igniter from a functional burner to one which was having issues. It sparked, but did not light. Any ideas?
  • sonrise Mar 31, 2009
    My Jenn-Air cooktop also has 2 burners that will not light. The gas is flowing and the ignitor is clicking, but no flame. I have tried to clean around the burner cap and in the crevices around the central unit, but to no avail. Is there another solution?
    President:
  • 878 Answers
Aknot, make sure each burner cap has a good ground to the burner. You can use some light sandpaper to scrub them. Where the burner fits around the ignitor is a small orfice. Use a paper clip or small sharp object to clean out the orfice. Try this first. Catriver..post back.
Posted on Mar 19, 2007
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
I have a GE JGP963 gas cooktop. When you turn the knob the igniters come on all the burners. The spark is good. This works on all knobs. But what happens is that it will not light. It appears there is no...
Hello, Is this a new unit? Is it still under warranty? Has it been recently worked on or converted to another type gas? I'd call the manufacturer (or the company that installed it) and have them send out a qualified technician to fix it. Are the burner flames a nice even blue color? Can you adjust the flames from high to simmer without them going out. If it was converted to another gas type, it's possible the wrong size orifices were put in or possibly that it needs to be converted because it is a natural gas unit that should be changed to propane, or vice-versa. Also be sure the appliance regulator was switched over to the correct type of gas. These are just a few ideas that come to mind. Let me know if any of these apply. Douglas
Sep 12, 2010 | GE 36 in. Profile JGP963 Stainless Steel...
Igniter ticks but burner will not light. Gas is flowing
The gas burner holes near the igniter made be clogged if you've spilled food on them. Use a sewing needle to clean the holes.
May 12, 2010 | GE 36 in. JGP628 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop Logo
279 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
