Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak home center program for my 3 in 1 scanning is not opening
Sorry it took so long to respond to your help, I am not able to get to the port behind my pc to unplug it and restart my pc and plug it in again to see if that does it, but as soon as I can get help with that I will try it, would it work if I unplug the back of the printer and restart or not?
  • susie174571 Dec 31, 2008
    Kodak home center will not open.
  • JDTec
    JDTec May 11, 2010
    I guess it has been too long, can you tell me what the original problem is?
Scan doesn't work, can't find on computer
Posted on Dec 26, 2009
Hi i want to open home center to scan and program doesnot open
please help me with this
Posted on Dec 25, 2008
When opening the kodak home center got an error.
it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Scanner will not work have just purchased the printer and have now got the print working but cannot get scanner working ?
scanning anything will ask for a place to save the document install kodak home center from cd or from net- www.kodak.com/go/downloads connect ur printer and computer with usb 2.0 open home center on computer
and try to scan a document by placing on scanner glass on the printer will be able to scan if not, call kodak 1800 419 1909 for further directions
Jul 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak easy share 5300 all in one printer will not scan
are getting any error msg like 1-2036 or anyother and are you using Vista or Xp,,,,try using the windows fax and scan settings....let me know and i will try and help you
Apr 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
On a kodak 5100 printer how do I scan a document to the computer to use ss an attachment for E Mail?
Thank you for allowing me to assist you in this question. Below is some basic information on how to scan with this printer. The Kodak Home Center software will save the file into a directory into your computer and you can use your email program to attach that file into your emails.
To scan to a file
1 Set the Default scan destination to File with the Kodak Home Center software.
2 Place your original face down in the right front corner of the scanner glass.
3 Press Scan.
4 Press Start. The original is scanned and saved to a file on your computer according to the scan settings in the Kodak Home Center software.
To scan to an application
1 Set the Default scan destination to Application with the Kodak Home Center software.
3 Press Scan.
4 Press Start. The original is scanned into Kodak Home Center where you can open it with the application of your choice.
Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Home Center will not open...Can't scan
I'm not sure if you tried this but download the clear utility from kodak here: http://www.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?osXPor98=winXP
You will need to click start, go to control panel, click add/remove programs, uninstall the kodak home center, unhook the printer from computer, then run the clear kodak utility. Try then to reinstall after. I always install the drivers before the software by plugging the printer into the computer and running the hardware wizard in XP and pointing it to the drivers on the cd then I install the software after. If you need more help or clarification let me know. If this helped you please rate, thanks!
Shawn
Jan 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
1. Open the Control Panel.
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
3. Select Microsoft .NET Framework 2.0.
IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
1. Follow steps 1 - 4 above.
2. Select Uninstall, and click Next.
IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
3. Restart the computer.
4. Perform a clean re-installation of the KODAK AiO Home Center software:
a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
NOTE: Do not disconnect your mouse or keyboard.
b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
vii. In the Ready to remove the program window, click Next.
viii. In the Uninstall Complete window, click Continue.
ix. Restart the computer.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
d. Run Disk Cleanup.
i. Open My Computer.
ii. Right-click Local Disk (C:) and select Properties.
iii. Click the Disk Cleanup button.
iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
e. Shut down all background applications.
i. Select Start > Run.
ii. Type msconfig in the Open field, and click OK.
iii. Select the Startup tab.
IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
iv. Click Disable All , then click OK .
v. When prompted, restart the computer.
f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
h. Before restarting the computer again, turn on the background applications.
ii. Type msconfig in the Open field and click OK.
iv. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
- If all background items were originally selected, click Enable All, and click OK.
i. Restart the computer.
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
455 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
