I checked all recomended things in my user guide. it worked this morning and just stoped mid cycle.
More than likely the operating coils are getting hot and opening. If it heats a little tomorrow after cooling back down but quits again replace these critters:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
