Question about Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 turns on then error 07,010.43:126070
The Xerox Phaser 8400 powers on then errors: 07,010.43:126070 and does nothing more. Any suggestions? Is this a hardware issue?
    President:
  • 2,072 Answers
Yeah it is a hardware issue. The code you are getting relates to the print head tilt and/or side to side movement.
One of 2 things occur to cause that code, these 2 things cause that code about 90 percent of the time.
1. When you remove the ( looking from the front of the machine as refrence) left cover, about 1/2 of the way back, on the bottom portion of the frame, you will see a 1 inch x 1 inch steel pivot block. Often times runoff from the excess tray or seepage down the print head will cause ink to build up in that block. That will not allow the print head to pivot back and forth properly causing that code. There is a spring over that block you need to clip aside to remove the block. It may be very sticky and a little difficult to remove. Channel locking pliers will normally allow you to remove it with some effort. I suggest putting the block in some pretty hot water . It makes the ink softer when hot and easier to remove.
You want to also picko ut all the excess ink in that are that you can to keep the block from gumming up again. Removing the print head is the best way to clean it, but that is pretty challenging if you donr know hte printer.
Now issue 2, is the print head wiper tacking to the print head. If the machine is not powered down properly or is unplug, or a power failure can cause this blade to be in the wrong position and stick to the print head. To access that, you want to remove the right and left covers, and also the ink loader, ( Where you load the ink sticks). It is held in by tabs and 2 plugs. Once you remove that ink loader you have access to the print head drum area. Look between the print head and drum for a pinkish colored blade, Gently detack it from the print head and run the cleaning cycle on the printer when reassambled.
The print wiper clutch could be going back causing the blade ot tack, but not as likely.
That code is definatly an issue with print head movement, and most of the time these 2 issues will resolve the problem.
Let me know, There are a couplf of other weird things that can cause this, But I doubt they are an issue.
Posted on Dec 16, 2008
Error code 13.387.48:106521 Phaser 8400 Print Count 110,000 Can this be Fixed
It can be fixed, but only by a Xerox authorised service centre. Xerox website tells you to turn it off and book it in for a service. Be prepared to pay a call out fee before hand. Here's the reference link for your error from Xerox website.
Mar 06, 2011 | Xerox Phaser 8400 Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Phaser 8400 error
When you power on the unit it goes through a series of tests to determine that the correct voltage is going to each system within the phaser. The error code you've provided implies a Preheater error 37,008.44
AC power supplied by power sources such as uninterruptible power supplies (UPSs) or DC-to-AC inverter systems may not supply correct voltage to properly power up the printer. Likewise, other devices sharing the same AC circuit can cause AC voltage sags that cause the printer to fail its AC heater PEST tests (Print Engine Self Test).
My first suggestion is to remove any other devices from the electrical outlet the printer is on, and then power it on.
If the error persists, you've got a hardware failure internally and would need to replace the preheater and deskkew assembley, Xerox PN 119641980
By the way, the last 4 digits in your error code are the current page count of your printer. This number is relatively low and thus it begs the question is the printer still under warranty? The part in question is about $110, however installing it will not be an easy task if you've never taken a Phaser 8400 apart or you do not have a service manual.
My suggestion, if the machine is out of warranty, is that you bring it to a qualified repair technician for service, unless you feel comfortable doing the repair yourself.
best of luck in any regard
Sep 01, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
Xerox Phaser 8400 Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
