Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave still not heating
I have replaced the magetron tube (under warranty) and replace the Diode. The only other two things I can think of would be the transformer or H.V. capacitor. Anybody got any ideas
  • 1 more comment
  • rws2911 Dec 16, 2008
    Now I've got it heating water very slowly, would the thermastat thats mounted on the magnatron cause this?
    OK checked that its getting 120Vac coming in...... going to check transformer
  • William Miller
    William Miller May 11, 2010
    The thermostat is just a switch that kills power to the oven if the magnetron gets too hot.
    (Magnetron overheating is usually due to a failing magnetron or a failed cooling fan, which is critical to protect the magnetron)
    You can test the resistance of the windings of the high voltage transformer: http://www.gallawa.com/microtech/xformer...
    Usually when a high-voltage capacitor goes bad, it will short, which will result in a blown fuse. Here's how to test it: http://www.gallawa.com/microtech/cap_tes...
    Also important for proper heating is correct line voltage (100-125VAC) and proper operation of the turntable and/or stirrer.
    Another possibility is a failing power relay on the control board.
    Let us know the outcome of your testing.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
if7
Posted on Sep 30, 2010
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven STOPPED HEATING
More than likely it's the magnetron and/or diode, chances are it may still be under warranty. Online owners manual states 5 year warranty on magnetron. Part only, service call and installation not included. Diode not covered. They require serial number, and will let you know if it's still under warranty. Installation appears to be simple, UNPLUG MICROWAVE THEN MAKE SURE YOU DISCHARGE CAPACITOR. INJURY OR POSSIBLE DEATH IF NOT DISCHARGED PROPERLY. Google how to install magnetron and discharge capacitor. It will save you approx $ 250 - 300 doing it yourself. Hope this helps. Be Safe
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Re: GE Microwave Oven #JVM1870SF001...turns on but will not heat-up item. Can it be the Magnetron and/or Diode is bad?
Dec 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL1800 wont heat and makes kind of a louder noise when turned on. How can I fix this?
on the microwave ,at the top is two screws to remove...one screw for thetouchpad...it opens up....please unplug the machine...safety first....when you open the the panel you will see a capacitor a oval shape on the wall,on the right side...there is a diode there...replace it....or the magetron is bad....then you will have to remove the unit....on the back panel rmove all screws...put them in a plasic container ,not to lose them...open it up .there is a magetron in the center...there will be four nuts holding it in on the top of themicrowave...replace it.....i hope this helps you....
Oct 28, 2009 | Microwave Ovens
My GE Microwave Oven is not lighting up, no interior light, nothing on the panel.
replace the fuse located under the outer cover, if new fuse blows, then either its a h.v. diode or h.v. capacitor or the magnetron tube is faulty
Oct 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Spacemaker
Yes, it could be the Magnetron. If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
61 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
