Question about Panasonic Lumix DMC-TZ3 Digital Camera
Hi I have a panasonic tz3 camera that when i turn it on it after 3 sec turns to please turn camera off and then on again the cover in front does not open up either any idea?
    Novelist:
  • 172 Answers
The cover not opening is a common problem with the TZ3, but this should not cause the waring message. Has the camera been bumped hard or dropped?
Try rapping the camera smartly against the heel of your other hand, or on a harder surface cushioned by a double layer of bath towel. You can also coax the lens cover open with a toothpick.
The error your seeing is common for lens problems, either unable to extend or retraced. Sometime you can overcome these problem by giving the lens or cover some manual help. Otherwise, repairmen on ebay buy them for repair, and working used ones are available on ebay at a good price, likely much better than what a local camera shop would charge you, and much better than what Panasonic would charge you.
If you take the ebay option, you can weigh the option of upgrading tp the TZ5, but the TZ5 is not worth upgrading to if bought new. Don't be fooled with a large pixel figure. TZ3 is a very nice camera to have. I love the wide angle and long zoom..
Posted on Feb 27, 2009
When I turn my Panasonic Lumix PMC-TZ3 on the lens does not open at all.... Please Help!!
Digital cameras have too many circuit connectors that could develop contact resistance without boundary lubricants. Cheaper to buy a new digital camera.
Jul 15, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
When I turn on my Panasonic DMC-TZ3, It gives me a "Please turn off camera and then on again" message. How do I fix this?
I HAD THE SAME PROMBLEM WITH MY TZ3, I AM KIRAN FROM BANGALORE, MY CAMERA WAS SERVICED BY PANASONIC SERVICE CENTRE-MATA ELECTRONICS ,NO86,1ST FLOOR, SP RD,OPP TO VIVEK COMPLEX ,BANGALORE. AND NOW MY LENS IS DOING PERFECTLY FINE. MR VIJAY IS INCHARGE AND THE CAMERA IS DOING GOOD, CONTACT MR VIJAY 9035871324 08022130711
Nov 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
When I turn my panasonic lumix tz3 on to take a photo, it struggles to focus and then says 'please turn camera off and then on again'. I do that but it just keeps saying the same thing. Anything I can do??
The problem is in the mechanical part of the lens housing, the motor that extends and retracts the lens is slowly seizing up, or the gears have ware and tare, or they need lubrication. This is a delicate job that require a camera technician to remedy the situation. If you continue to use the camera it will eventually stop working.
Jan 15, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-TZ3 goes right to 10X zoom
There is a solution to this problem discussed here http://www.fixya.com/support/t159240-buttons_stopped_working
Aug 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-FX12, not working
if it is out of focus. try holding down the menu/set button while you turn it on hold it for about 5-10 sec after it comes on it worked with my DMC TZ3
Jul 01, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
The camera does not work
Iam sorry iam afraid the barrel is broken(did you dropped it on the lens?
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic tz3 cover gets stuck
Common problem with TZ3. You can try to lub lens cover using graphite lub. Use it sparingly and after lens works, wipe off excess with dust cloth. Be sure not to get any on lens itself.
If lub doesn't work, you can pull out the lens cover altogether and find a manual lens cap the will fit.
The other option is to sell it on ebay to a repairman in a auction and replace it with another working used ones. Keep your accessories and by a used one cheap without accessories.
Nov 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
How tu use video recording..
The picture that I posted shows a TZ3 mode dial. I added a blue arrow to point out an icon on the mode dial.
1. Turn the mode dial on the camera so this icon is selected.
2. Switch on the camera.
3. Aim the camera at your subject, press the shutter button halfway to focus, then press it fully to begin the video. (Just as you would take a picture.)
4. To stop taking video, press the shutter button fully again.
~When a video starts being taken, its current length will appear on the camera's LCD screen.
~Videos take up more space on the memory card than do pictures.
~If an SD memory card becomes full while recording, then the video will stop automatically.
~Videos can be played back on the camera's "PLAYBACK" mode. They can also be viewed on a TV or downloaded to a computer.
Jul 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
234 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
