Question about Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up
Anti-lock brake system light comes on as well as the traction control light. 97 528i bmw my abs light came on and my car will not go out of 1st gear...could this be a major problem
  • 25 Answers
Abs sensor in one of the wheels is dead
Posted on Feb 18, 2009
ABS & Traction control light are on, what is causing this?
About 39,700,000 results (0.44 seconds) Search Results
    Traction Control Light is on Inspection - YourMechanic
    www.yourmechanic.com > Auto Repair and Maintenance Services
    As a result, sometimes an issue in the ABS can trigger the traction control light. If this is the case, then both the ABS and Traction Control lights will be on.
    My anti-lock brakes and service traction control lights came on ...
    https://answers.yahoo.com/question/index?qid...
    Oct 16, 2006 - I drive a 2000 chevy impala...i have 135,000 miles on my car. ... The problem is that starting in '92, Anti-Lock Brakes are controled electronically, so if there is a problem with the sensor, your ABS might fail when you need them the most. ...ABS (?nti-lock Brake System) is a ...
    How To Fix ABS & Traction OFF / Service Traction System ...
    ? 5:35
    https://www.youtube.com/watch?v=KFQphWamcjQ
    Feb 17, 2014 - Uploaded by Zero Gar
    How To Fix ABS & Traction OFF / Service Traction SystemLight Monte ... side connector that leads from the ABS controlmodule to the speed ...
Feb 05, 2016 | Cars & Trucks
What does it mean when my anti-lock brake light comes on and the low traction light comes on and shuts off?
You need to have the ABS system scanned. You probably have a bad wheel speed sensor. most likely located in one of the hub bearings meaning; you may have to replace a hub wheel bearing assy with the faulty sensor. Traction control uses the same speed sensors as ABS. when the warning lights are on the system is not working.
Jan 21, 2016 | 1995 Chevrolet Lumina
2000 buick regal , track light on, anti lock brake light on???
You will need to take it to the GM dealer or any well equipped brake shop and have the system ABS/Traction Control system computer scanned, a fault has occurred in the system and at this time you have no Traction control or Anti-Lock brakes. When the lights were turned on the systems control module stored a code for the fault in the system. The ABS and Traction Control are one in the same system.
May 20, 2011 | Buick Regal Cars & Trucks
Abs and tcs lights on what do they stand for?
ABS stands for anti lock brake system.
TCS stands for traction control system.
I recommend having your abs system diagnosed for faulty sensors, control module, etc. With the abs light on the traction control system is designed to disable because it utilizes the abs system to automatically help control your vehicle in loss of traction situations.
Dec 19, 2010 | 2000 Hyundai Sonata
Abs light is on and tractiioncontrol light says off but cant turn it back on with switch
abs light means that a problem is being sense in the anti lock brake system, Traction control only activates when needed and is not related to the abs light, if you turn the traction control on and try driving and making the car slide the traction control will activate.but as for the abs light you need to get your brakes checked.
Dec 06, 2010 | 1998 Buick Regal
My traction control light and my abs lights keep coming on what does that mean and how do i fix it?
The abs is your anti-lock braking system. It may work with your traction control light, I'm not sure. But you apparently have a problem with your anti-lock brakes. It could be the hydraulics or it could be the brakes themselves. I would have it checked out.
Jul 14, 2010 | Cars & Trucks
Traction control and anti-locks(ABS) lights come on.
Traction control and anti-locks(ABS) lights come on there is sensors that are pluged in behind the rotors check and see if they are disconected or loose sometimes when you change your brake pads they might come loose and not making contact.
Jul 06, 2010 | 1998 Cadillac DeVille
Abs problem
It sounds like maybe the ASC/DSC control unit may be bad. I would first check the RR wheel speed sensor for damage or water ingress. Unless you know someone that has a scanner, I would take it to your local dealer and let them scan your system.
Mar 08, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Problem with my cruise control and ABS light on 03 Explorer
Anti-Lock Control —Vehicles Built After 03/2002 The 3-channel anti-lock brake system consists of the following components:
  • front wheel speed sensors
  • front wheel speed sensor rings
  • hydraulic control unit (HCU)
  • Anti-lock brake control module (ECU)
  • rear wheel speed sensor
  • rear wheel speed sensor rings
  • yellow anti-lock brake warning indicator
The 4-channel anti-lock brake system with traction control and stability assist system consists of the following components:
  • active brake booster with integral solenoid
  • brake booster release switch
  • stability assist module (ECU)
  • stability assist event indicator
  • lateral accelerometer
  • longitudinal accelerometer (4x4)
  • rear wheel speed sensors
  • steering wheel position sensor
  • yaw rate sensor
  • brake pressure transducer
  • traction control switch
I suspect the abs issue is causing the speed control not to work if it happened at the same time the cruise control stopped working. When the yellow ABS light comes on, it means the ABS is dactivated. You may have a faulty accelerometer which senses acceleration and yaw (side to side lean). I have not seen a bad one but you said it is sensitive to acceleration.
I would unplug it and see what happens. The connector should have a small tab to depress so you can pull the connector out.
Here is where it is:
Accelerometer Removal and Installation
  1. NOTE: The accelerometer is located under the center, rear passenger seat carpet. (I think you have to remove seat for access).
    Cut the carpeting along the perforations.
  1. Disconnect the electrical connector.
  1. Remove the nuts and remove the accelerometer.
Have dealer hook up tester and pull fault codes if you can't find an easy solution.
Some background info
  • A malfunction in the anti-lock brake system will cause the anti-lock brake control module to shut off or inhibit the system. However, normal power-assisted braking remains.
  • Malfunctions are indicated by the yellow ABS warning indicator in the instrument cluster.
  • The anti-lock brake system is self-monitoring. When the ignition switch is turned to the RUN position, the anti-lock brake control module will carry out a preliminary self-check on the anti-lock electrical system indicated by a three-second illumination of the yellow ABS warning indicator in the instrument cluster.
  • During vehicle operation, including normal and anti-lock braking, the anti-lock brake control module monitors all electrical anti-lock functions and some hydraulic operations.
  • Each time the vehicle is driven, as soon as vehicle speed reaches approximately 20 km/h (12mph), the anti-lock brake control module turns on the pump motor for approximately one-half second. At this time, a mechanical noise may be heard. This is a normal function of the self-check by the anti-lock brake control module.
  • Pedal pulsation coupled with noise while braking on loose gravel, bumps, wet or snowy roads is normal and indicates correct functioning of the anti-lock brake system.
  • Warning Lamp Indicator
    The anti-lock brake system (ABS) uses the yellow ABS warning indicator to alert the driver of a malfunctions in the ABS.
    The yellow ABS warning indicator will come on to warn the driver that the ABS has been turned off due to a symptom that exists in the ABS. Normal power assist braking remains but wheels can lock during a panic stop while the yellow ABS warning indicator is illuminated.
    Please report back, I am curious if that is what it is. Good luck
    Mar 03, 2009 | 2003 Ford Explorer
    Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up Logo
    495 people viewed this question
    Top Pro-Fit Car Audio & Video Experts
    greg benton
    Craig Butler
    Craig Butler
    Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
