Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
LAcie Big Disk 1 T - not mounting
HI. I have a Lacie 1 T storage Big Disk. I have had it for ages and now suddenly it will not mount on my apple G5 desktop.The blue light is flashing and the machine is whirring or spinning but nothing shows up.I have urgent back up stuff on this machine and I am at my whits end - can anyone help?Thanks in advanceMartin
  • 599 Answers
Have same unit and had same issue...once i shut everything down..computer/power/power to le cie and all back on it worked for me... not sure if this helps for you likely tried that b4 posting ..other possible fix is uninstall drivers/reinstall the le cie recovery cd with the drivers on it ...good luck
Posted on Dec 15, 2008
    Master:
  • 479 Answers
First of all you need to check out the connections.and it could also be the problem of any thing gone loose on the board check out that also.
    Top Expert:
  • LaCie Master
  • 81,400 Answers
Did U think that maybe the drive has failed? do u have another computer u can try it on? that would be the quickest way to test it.
I bought a LaCie 600GB Big Disk USB 2.0 ( 300990U ) at a garage sale and my Dual 2 Ghz Power PC G5 doesn't seem to recognize it. I am running on OS 10.4.11. The power supply seems to work and I have tried...
Chances are it is formatted in a way that OS X cannot detect. See if you can format it using the Disk Utility and then see if that allows it to mount the drive then...
Mar 27, 2011 | LaCie Big Disk (300990U) (LAC300990U) 600...
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
My lacie Big disk 500GB drive will not mount
If Lacie does a kind of tickling noise that is the disk head. It means the disk is faulty.
I will post this on main thread.
Aug 28, 2008 | Computers & Internet
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Lacie big disk 2.0 usb
For anyone with a Big Disk drive that doesn't get recognised by Windows and gets a TUSB 6250 message in Device Manager, the cause is very likely to be the power supply. Although the drive will be powered up, it is not spinning at the correct speed. I tried all of LaCie's technical support suggestions, some of which are outlined above and none worked. They finally suggested getting a new power supply. This solved the problem (Wattac, £22). This problem has affected a lot of LaCie Big Disk owners...
Mar 26, 2008 | Computers & Internet
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
62 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
