Question about Harman Kardon AVR 235 Receiver
Sound is There Then its Gone!
The Sound just stopped, power is still on, Tried analog inputs ; no go. I have the main display but also the OSD menu does not come on to the TV, it displays on the RCVR display but have no idea where it is in the menu! tried the TEST for audio channels it is working on the display but no sound. Thought it was a fuse so I opened the cover and checked the obvious ones...there ok!. There is also a fan inside and when the power is on it does not seem to operate. I have not tried it outside the unit yet. Anyone have the schematics for it? Then I would be able to troubleshoot it! Was it just the end of its existence! I sure don't want to take it to Radio Shack @ $500/hour!!! Any assistance will be greatly appreciated!! Thanks
  • Anonymous Feb 27, 2008
    no sound coming from my avr235, although it's lit up like a christmas tree...need help, cheers
  • shephp01 Jul 07, 2008
    I have an AVR335 receiver that lost its sound too. I took it apart to see if any obvious burns or other malfunctions could be seen. Everything looks fine but what I gather is a small thermal protector screwed to the heat sink could be the source of the problem. It has a 2-wire cable that is soldered to the amplifier PCB near the two sets of wires that go to the fans. Does anyone have any info on the sensor and/or how I can test the sensor? I have pictures if they would help.
    Paul
Since the power still on,and soun d is automatically down try to recheck the audio very well and check over the ringer or buzzer.This by wizzard technology ltd.
Posted on Mar 19, 2007
  • smart john Mar 19, 2007
    i have problem on repaired all phone network,i have been find way out about this problem.
    President:
  • 3,130 Answers
You will need to trouble shoot the audio output amp section. It sounds like the unit is in a shut down or a protection mode. Good Luck
My Rotel RSP-976 analog inputs don't produce sound. I did all the OSD settings but to no avail
Hi Awal. Interesting problem. Have you tried another pair of leads? What source are you using please, cd tuner etc? I noticed the the names for the five audio/video inputs can be customized by the user, Maybe there is a firmware issue? With the unit being surround sound Have you tried running in 2 chanels only?
Jan 06, 2015 | Rotel Audio Players & Recorders
The problem is it shows red in picture tried to adjust cant get it out , do i need a new lamp
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    • You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    • If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
(02)
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It
Dec 24, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
No sound when connecting optical cable from set top box to #4 optical input for cable tv on rear. The cable only works from the front input or the dvd input on the rear but that limits my sound fields. I...
Make sure your "Input Select" "Audio" portion of the main menu is set to "Auto" you may have it in analog thus only allowing audio from the front analog input. Also check your digital input select option as well. you may have it assigned to another source input. Go into the main menu of the receiver and you will find all the settings. Hope this helps. If you still have issues, post a comment and I can help you troubleshoot further.
Feb 26, 2010 | Yamaha HTR-5760 Receiver
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
No audio for DVD/CD inputs
Has the DVD settings been altered so that it's now putting out an analogue signal?
Jul 01, 2017 | Harman Kardon AVR 430 7.1 Channels...
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Help with my 190S monitor
The OSD button has gone faulty.
The button will need to be replaced , or it might just need spraying with a contact cleaner like RP-7 or WD40.
Both solutions will require the removal of the front cover to access the button.
Jun 06, 2008 | Philips 190B6CB/27 19" LCD
MONITOR FREEZE
Hi
You need to hold down the monitor menu button and you will get the msg on the monitor tht the OSD menu is unlocked....
It will take about 10-15 seconds....
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Harman Kardon AVR 235 Receiver Logo
206 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
