Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
Posted on Aug 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Squeaking front forks
When i push down on the front forks it squeaks like there's metal scraping on the stanchions
Anonymous
Level 2:
Sergeant:
  • Expert 186 Answers
  • Posted on Aug 02, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
186
Questions
Helped
75157
Points
522
Needs hydro oil or seals
1helpful
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 • Dryers
Squeaky shocks on 2007 screamin eagle dyna
Are you talking about rear shocks or front fork tube/slider assemblies, either way there should be NO squeaking. Is there something on rear shocks that is contacting and rubbing?? Is any mounting hardware loose. Otherwise you probably need new shocks. Front fork tube should not be squeaking and could not likely be dry ie no fluid inside or you would notice poor ride quality. Otherwise there should not be anything that could/would squeak up there. Maybe it is not a shock that is squeaking but something else in that area that is loose or rubbing.
Is there grease nipples around wheels of caravan
Is it a brake squeak? Some vehicles have a little metal tab on the brakes that starts squeaking when they get close to needing to be replaced. When you push the brake, the sound may go away due to the pressure being applied. Check your front brake pads.
1helpful
FRONT END SUSPENSION Squeak
It is hard to tell with out more detail as to what makes it squeak. Does it squeak when you hit a bump, or while the vehicle is in motion? To test your struts simply push down on each front corner (above or next to headlight)as to rock the vehicle up and down. Pick a solid part as to not dent it. This is a good way to test your struts. If it goes up in a stiff motion(not rocking) its probably good. If it goes up and down easily and has a lot of play then your struts might need changes. The squeak could also be sway bar bushings as well. If it only squeaks when your in motion it could be your cv axle. If you are still in need please post more detail as to better diagnose the issue.
Squeak front wheel
depends on what type of pads are in if they are a hard pad they will squeak some times it depends on the weather if its damp a softer set of pads will stop from squeaking you could also try cleaning the rust away from the outer edge take wheel off then by hand turn disk use a spoon or a blunt pice of metal to scrape off the rust normally solves the problem also can try putting copper grease on the back of the pad so when you take your foot of the break pedal the grease sort of sucks the pad off the disk hope this makes sence chears ivan
1helpful
Front brakes continue to squeak.
to help with pad squeel when you take brake pads out clean all rust from the caliper where the pad slides and put some copper grease on the areas that contact this should help, while you have caliper off check the slider pins too as they may have rubber stuck to them, if they do buy new pins or scrape rubbish off and copper grease them up too, hope this helps.
Noise
Check Exhaust System Heat Shields
Get under vehicle & push up & pull down on it,
to duplicate the movement on the road.
4answers
My truck is squeaking when making right turns and over every little bump. I also pushed down on the box of the truck & could hear that the noise is cominhg from the front. I was told it could be a...
Check your sway bar links, the two bars at each end of the sway bar, connecting to the lower control arms. Sometimes you can spray them with silicone. Most likely have to replace them. Hope this helps. TJ
2answers
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2011 • Dryers
1helpful
Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Jan 13, 2010 • Cycling
Top Mongoose Cycling Experts
vince
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
