Question about Candy 24 in. CD622 Free-standing Dishwasher
Candy cd623 uk dishwasher water not heating up
Hi, I have the above dishwasher and the water remains cold...i am sure it is the heating element. i have looked all over the dishwasher but cannot find where the element is hidden...Can anyone help in advising me exactly where it is and how to remove it??? thanks in advance for any assitance its appreciated!!
We had the same problem with our Zanussi dishwasher and it turned to be not the heating element but something wrong with a part of the circuit board, a memory part that tells the machine to heat the water. It was fixed very quickly. We had almost invested in a new heating element!!
Posted on Aug 03, 2007
    President:
  • 1,462 Answers
Not familiar with model. element can be inside cabinet in which case it will be obvious or may be in a cylinder heater mounted in the base. suspect stats as well or possibly the module
Posted on Mar 20, 2007
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
Instructions or Manual required
Actually every dishwasher I've worked on had one water inlet and it was always for hot water. Approximately 3 gallons per cycle.
Mar 25, 2014 | Candy 24 in. CD623 Free-standing...
Candy CD242
Try this link & check that model number. They had a 252 but no 242: http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=3
I need the operating instructions for a candy aquaviva cd623 dishwasher. Can anyone help with a pdf version I can download?
I am sorry to hear that you have problems with a candy dishwasher. I have had two or three pieces they just died of old age.
But seriously on line there is this manualsonline.com
You will most certainly find your candy manual there for downloading free.
Goodluck
kolbrun
Mar 24, 2012 | Candy 24 in. CD623 Free-standing...
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwasher won't dry.
run it and open it after the drying cycle right away. what you should be looking for is heat. you will see a metal rod going around the bottom of the dishwasher in a square shape either that has stopped working or the circuit shorted out some where, people don't usually know this but dishwashers use only cold water they use that element to heat the water.
good luck
Feb 10, 2011 | Kenmore Dishwashers
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
Candy 24 in. CD622 Free-standing Dishwasher Logo
485 people viewed this question
Top Candy Dishwashers Experts
ptpumpman
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
