Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Upright freezer is leakng from the bottom of the door
Only started after defrost. Freezer seems to be working fine, but there is a slow drip from the bottom right side corner. Any thoughts?
  • 85 Answers
Pull out lower bin and check at back to see if you have ice build up. if you do the defrost drain tube is blocked
Posted on Dec 15, 2008
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright fridge--freezer door drips when cleaning
Condensation has formed and frozen behing the door panel. You can live with it, or take apart the panel and dry it out - you may have to replace some insulation. Hope this helps!
Feb 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Maytag Freezer
sounds like you need a new door gasket
Aug 15, 2007 | Magic Chef 11.8 cu. ft. / 334 liter...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
