Question about Honeywell Programmable Thermostat Heater
Heater comes on at 5:10 am prior to the programmed setting
I have a honeywell thermostat model YRTH6300B1007. It is programmed to come on at 6:00 am but comes on at 5:10 am even though the room temp is 5 degrees higher than the setting to come on. It says "recovery". How can I fix this so that it comes on at the programmed time. The only time it occurs is in the early morning. Thanks.
  • 61 Answers
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
We have a Honeywell Digital thermosat. We just put brand new batteries in it and it is still showing lo battery.
on most of honeywell units if you pull the face of the thermostat off there is a reset button you can puch and reset try this.... if it does not have a reset remove the red power wire on the "r" terminal and if you have a wire hooked to the "c" terminal remove it at same time ///take batteries out prior to doing this and it will reset the program in thermostat... if the display comes back again with the lo battery the thermostat internally has a issue...good luck
Jan 09, 2011 | Honeywell Programmable Thermostat Heater
How do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Oct 10, 2009 | Honeywell Programmable Thermostat Heater
Accidentally programming it
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 07, 2009 | Honeywell CT500 Digital Heat / Cool Manual...
Air suddenly not coming on Honeywell RTH230B
for starts, check fuses in disconnect box by condensing unit
Aug 20, 2009 | Honeywell Programmable Thermostat Heater
Cannot get thermostat to work with previous owners programming.
turn the power off to the thermastat for 5 min (should be a switch on unit) and it should reset
Dec 11, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat problem
Model number should be on the label inside the tstat
Nov 13, 2008 | Lasko Ceramic Heater w/Adjustable...
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
719 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
